Advice on what jack to use
Results 1 to 20 of 32
    Dec 2015
    Thanked: 13
    Default Advice on what jack to use
    Hi Guys,
    I have a quick question.
    I recently raised my Navara about 5" all round (levelling raise), and I am struggling to get the wheel off the ground with the standard scissor jack.
    I was wondering what other options I have with regards to a jack that can give me a higher lift. Was considering a High Lift, but I have the original round tube side steps, so not sure if it will be a viable option.
    Thanks in advance.
    Mar 2007
    Harties Boet
    Thanked: 753
    Default Re: Advice on what jack to use
    Id get a bottle jack, and jack up on the axle/hub, or whatever is connected to the wheel (wishbones? I dont know the terms), ie, push the wheel up, dont let it sag
    2004 Nissan Patrol 4.8
    1999 Nissan Patrol 4.2D
    King Williams Town
    Thanked: 972
    Buy a 6ton bottle jack, get a few blocks of wood and you away.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
    Thanked: 11242
    Jack up under the suspension, not the body.
    Dec 2015
    Thanked: 13
    My concern with using a high lift.
    Thanks guys.
    I will look at the bottle jacks. Still would like a high lift for the other versatile uses.
    Dec 2015
    Thanked: 13
    Would a 4 ton bottle be okay?
    I am thinking about it fitting behind the rear seat.
    Thanked: 11242
    Quote Originally Posted by King_Triton View Post
    I had one for many years. I think I used it once and a proper trolley jack would have worked better.
    Thanked: 987
    Have a look at the height of the suspension and lift required. It is not so much the max weight as the required lift.
    For offroad use I much prefer an air jack, much safer
    Stay Safe
    Disco-Deon
    This morning I woke up,
    Making today a great day.
    Nerdy, 2011 Honda Jazz, 1500 Exc
    Dec 2015
    Thanked: 13
    Trolley jack would be my option too, but want something that is not bulky to carry with
    Dec 2015
    Thanked: 13
    Quote Originally Posted by Disco-Deon View Post
    Definitely on my wish list... Need to budget for one next year
    Pretoria, Hartbeesfontein
    Thanked: 684
    I personally do not like the bottle jacks especially when they start leaking. The jacks of the toys and isuzu are very nice, they work on a gear basis
    Robert
    '09 VW Caddy Maxi TDi
    '06 Citroen C3 1.4HDi8)
    '97 Isuzu 280 S/C plaasbakkie
    Thanked: 11242
    absolutely
    and a flat square piece of pine plank, roughly 8x8"
    Tshwanetoria
    Thanked: 678
    Thanks guys.
    Mobi-Jack. The have a two-stage one.
    http://www.mobi-jack.co.za/bottle_jacks.htm
    And get a proper base, as said above
    Dec 2015
    Thanked: 13
    Thanks. That's the type I plan on getting.
    A flat base is a must.. thanks guys
    Tshwanetoria
    Thanked: 678
    That orange plastic base for a high lift jack works a charm, safe and light, but expensive
    King Williams Town
    Thanked: 972
    Trolley Jack's are 2 ton which is hand able but bulky and hard to jack with imho. My 6 ton bottle jack is about the height of a 500ml coke bottle. I just find it easier to use a 6t bottle jack than a 2t trolley jack.
    215/80/R15c tyres
    GPS,Bluetooth
    snorkel soon
    Craig
    Jul 2017
    Thanked: 104
    I use 2 types of jacks. A mechanical bottle jack with extended sleeve, just for getting the tyre off, and a high lift jack. Both work well. The bottle jack fits the cars existing mounting position. You have to use it under suspension though.
    https://www.midas.co.za/pebble.asp?relid=1713&t=75
    I don't like the hydraulic bottle jacks as in my car they are stored sideways and this seems to make them fail. I have gone through so many.
    2008 Ford Ranger 3.0 XLT 4x4
    Jul 2017
    Thanked: 104
    Not the base plate I use but not too expensive.
    https://www.outdoorwarehouse.co.za/p...lift-jack/6527
    Feb 2012
    Chintsa East
    Thanked: 435
    Hi Guys,
    Thanks in advance.
    I am past lying under a car to get a jack in. I carry a high lift jack, a jack buddy and a collapsible axle stand.
    Loosen the wheel nuts, jack with the jack buddy on the wheel, insert axle stand, change wheel. Reverse procedure to lower.
    2013 Disco 4 XS Lifted
    Wartburg
    Thanked: 1182
    They are good jacks, but the "2-stage" is misleading. They count the threaded top as one stage. The hydraulic part is only 1 stage.
    Midas used to sell a proper 2 stage. They called it a 3 stage, also counting the threaded section as a stage. I don't see it on their website anymore.
