Paging Stephan . . . Is that tensioner self-adjusting?
It has an a-centric nut. So without disassembling it, I have not really gone into the mechanism. Don't want to do that tonight and then being stuck.
On my Golf 3, (way back) it was mounted on a spring loaded arm, so the spring provided the tension.
I have got 3 of them in my household. Johan the tensioner pulley is still using spring tension to tension the belt. Similar to the Amarok. You also need to put a pin in place after relieving the tension on the pulley to change the belt. Very award and little space to work in. If I remember correctly, the bolt which fastens the pulley to the arm is left hand thread. Enjoy
Groetnis
Koos
Johan, 16 ring spanner om spanning op te neem, as ek mooi kan onthou (of miskien raak ek nou deurmekaar met die Amarok) en n 5 of 6mm allen sleutel om hom in plek te hou. Sal bietjie weer gaan loer. Wat ek wel onthou is dat die spasie klein is.
Groetnis
Koos
yeah self adjusting spring tensioner. 16 spanner to undo and yes it is akward. usually you have to buy the entire tensioner and not just the pulley and getting the entire tensioner out is an absolute mission so sometimes the solution is just buy the whole thing and swop the roller. yes reverse thread to undo the bolt holding the roller.
VW Touareg - 2005 - V10 TDI
VW Touareg - 2009 - V6 TDI
Thanks Stephan. Good to know my memory is not that bad.
Groetnis
Koos
Maybe I should just install a new belt only - since the age (6 years) and not the km (about 40 000) of the existing belt is my main concern. I am not sure the age thing applies to the roller.
The vehicle was "inactive" for 3 years, only driven by me once a week whilst my daughter was overseas. I did all the other service items once a year.
change just the belt you will be fine
