Discovery 2: Build and assembly of 4.6L V8 - Page 5
Page 5 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 81 to 100 of 164
  1. #81
    Langebaanweg
    Thanked: 808
    Default Re: Build and assembly of 4.6L V8
    This wear is where you will lose performance.
    Here's a link to my "go to" V8 site.
    They even taught me how to do the shimming of the rocker shafts, something that isn't in my manual.
    When I rebuild mine, I was surprised with the amount of extra power I gained and my engine was only rebuild because I had a itch.
    There is a lot of useful information on this site.
    http://www.v8engines.com/engine-4.htm#worncams
  2. #82
    May 2011
    Klipriver
    Thanked: 239
    Thanks for this, now to look a bit closer at myblown motor and check a few things, but it seems to be pointing towards a previous poor rebuild
    Alan
    _________________
    Range Rover P38
    Series 3 109 SW (Tortoise)
  3. #83
    Langebaanweg
    Thanked: 808
    Also have a look at the head gasket part.
    If your engine has 3 rows of bolts, follow their instructions.
  4. #84
    Thanked: 1610
    As far as I recall, the 3rd row was done away with on the SD1 already, so that shouldn't be an issue.
    If they are fitted, the Rover P6 guys say just to nip them up so they don't fall out the holes or omit them entirely.
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  5. #85
    Langebaanweg
    Thanked: 808
    Jip.
    I call it LR's dirty 20 year secret.
  6. #86
    Aug 2010
    Centurion, Pretoria
    Thanked: 103
    Man oh man... Cannot wait to see the end result, and to hear it...!
    2011 Freelander 2 SD4 HSE AT.
    1999 Discovery II V8 XS AT.
    2016 Campmaster Compact 100 trailer.
  7. #87
    Jan 2016
    Golf Park
    Thanked: 171
    Spent the afternoon getting some elbow grease under the finger nails cleaning valve covers and rocker parts.
    I am not happy with the rocker shafts looking at the scouring marks and even though the rocker arms themselves look good i am not happy to reuse the arms on new shafts so it looks like will be doing complete new rocker assemblies.
    To answer some previous questions, I am installing new lifters, new CAM and new push rods.
    I will also be going through the tedious process of checking tappet pre-load.
    Old motor will be out tomorrow.
    Before and after scrubbing.
  8. #88
    Thanked: 1610
    Quote Originally Posted by Jay_B View Post
    I wonder what an exercise like this would run to, cost wise, in SA?
    https://classicroverforum.net/index....t-issue.40032/
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  9. #89
    Jan 2016
    Golf Park
    Thanked: 171
    Thank you for the link, i was actually thinking last night why there is not bushes pressed into the rocker arms.
    Reading that thread confirms something i was told as well regarding aftermarket shafts and rocker arms, that does leave me in a tough spot though.
    There would be a few places around that could machine new shafts according to spec and then possibly reuse old arms and pedastills with bronze bushes pressed in?
    Unfortunately everyone is still closed for the festive season and time right now to get that done is not on my side.
    Going to give LR a call later and see what they have available in the warehouse.
  10. #90
    May 2011
    Klipriver
    Thanked: 239
    You can use mine
    Alan
    _________________
    Range Rover P38
  11. #91
    Thanked: 2427
    Pitty one cannot install roller rockers.
  12. #92
    Jan 2016
    Golf Park
    Thanked: 171
    I reached out to someone i met a few weeks ago while collecting my heads, he is an engine builder and machinist, meeting with him next week to look at machining new shafts and then installing brass bushes onto the rocker arms.
    Phoned LR but all those parts are discontinued.
  13. #93
    Jan 2016
    Golf Park
    Thanked: 171
    Quote Originally Posted by All -in -one View Post
    You can use mine
    Hey Alan, are yours still in good nick?
    It then leaves you without anything though.
  14. #94
    Thanked: 1610
    One can!
    http://store.yellaterra.com.au/ta-pe...oller-rockers/
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  15. #95
    Thanked: 1610
    If you have the time and inclination, Volvo steel rockers from the B18 engine can be made to to work, but they are 1.5 ratio, while the RV8 is 1.6, so they would require offset bushes to be made up to fit the Rover shafts and deliver the correct lift unless you use a 1.5 ratio profiled cam. They need bushing anyway to fit the shafts.
    The GM V6 3.8l engines should also work, as well as Oldsmobile 215 rockers with rebushing for size.
    Problem is, all these are scarce items due to age.
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  16. #96
    Thanked: 2427
  17. #97
    Jan 2016
    Golf Park
    Thanked: 171
    Quote Originally Posted by customrv View Post
    Hey Pieter,
    Did they produce the stud with the longer threads? I remember the last info it was too expensive to make us a batch
    I only built one motor with those short studs and drilling the first 5mm out to drop the stud down, but 4 years later one of those studs did pull out!
    EbenH.
    For thos interested see below the comparison of the correct ARP studs that arrived this morning compared to the ones supplied from Rimmer
    Correct bolts on the left and the older model on the right
  18. #98
    Jan 2016
    Golf Park
    Thanked: 171
    Another day of elbow grease cleaning parts off the old motor, if I see anymore silicone where it shouldnt be I am going to throw this motor like the hulk across the yard.
    Honest question, am i missing something with the use of gasket maker over the use of dedicated gasket sets, for example on the front cover? My problem is the silicone has gone to places it shouldnt; (Eg: physically in and on the timing chain)
    Anyway finished the day with fitting the first head.
    The studs just look oh so pretty and are far nicer to use than head bolts, also using an Elring head gasket set rather than the Brit part one that came in the set.
    Have not torqued the nuts down yet, my spline socket seems to have found legs
  19. #99
    Langebaanweg
    Thanked: 808
    I use Locktite silicone on all non specialized gaskets, but I first clean all metal surfaces with benzin,then I "rub" both sides with the silicon.
    It's less than a quarter of a multimeter.
    Looks neat and doesn't peel out.
  20. #100
    Thanked: 2427
    Your engine looks Awesome.
    On silicone I hate it. Once rebuild a Ford 3.0l Essex V6. Opening it up I found it dropped a main bearing. Piece of silicone stuck in the oil port.
