Discovery 2: Build and assembly of 4.6L V8 - Page 12
Page 12 of 12 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12
Results 221 to 239 of 239
  1. #221
    Thanked: 16373
    Default Re: Build and assembly of 4.6L V8
    Exhaust bandage wrap will help, but you can't use that at the coast as the headers rust off. Luckily you're in Gauteng.
    Another alternative is more insulation/heat proofing on the tunnel.
    Lastly, don't discount the heat generated by the transmission. Are you running the ZF or the R380 or what?
    Jakes Louw
  2. #222
    Jan 2016
    Golf Park
    Thanked: 224
    I have the R380, new oil done less than 10k km ago on both gearbox and TC.
    Insulation on the tunnel i have thought about but would need to drop the gearbox out to do it neatly and properly.
    I have also though of the bandage type wrap but also no real info on how effective it is.
  3. #223
    Thanked: 16373
    Quote Originally Posted by Jay_B View Post
    Basically better than nothing.
    The other alternative is aluminium heat shields but again, access to the tunnel.......
    You running a gearbox oil cooler? https://www.ashcroft-transmissions.c...ooler-kit.html
    Jakes Louw
  4. #224
    Jan 2016
    Golf Park
    Thanked: 224
    Yes have the standard oil cooler that came fitted from LR
  5. #225
    livingstone
    Thanked: 165
    Also look at one of these for the transfer box
    LT230 High Capacity Sump - Ashcroft Transmissions
  6. #226
    Jan 2016
    Golf Park
    Thanked: 224
    Quote Originally Posted by tripodontour View Post
    Have seen that before but done think that is the issue causing all my heat.
    Read yesterday about an insulating foam around the heater matrix in front of the center console so i am going to have a look at that first.
  7. #227
    Mar 2015
    New Germany
    Thanked: 563
    My R380 which has a oil cooler not the std loop pipe but a 8 row cooler, the oil stat opens around 80deg so oil in R380 can get upto 90deg, I also have the extended sump on my LT and oil in there can get up to 90 -110 on long trips,
    2005 Defender TD5
  8. #228
    Nov 2011
    Langebaanweg
    Thanked: 1358
    Wow! That's hot. I've never seen those temperatures.
    Mine has standard bottom plate and no cooler.
    I have only seen mid to high 80's °C.
    '07 Land Rover Defender 110 TDI 300 Kalahari (Meisiekindē)
  9. #229
    Mar 2015
    New Germany
    Thanked: 563
    was on a drive for 14hrs up into Moz
    2005 Defender TD5
  10. #230
    Nov 2011
    Langebaanweg
    Thanked: 1358
    The 300Tdi or LS1?
    Sounds like you were in a rush 🤪
  11. #231
    Thanked: 16373
    The loop pipe or a PROPER radiator cooler?
    Jakes Louw
  12. #232
    Jan 2016
    Golf Park
    Thanked: 224
    proper radiator cooler
  13. #233
    Jan 2016
    Golf Park
    Thanked: 224
    Some more updates and insights...
    we did another weekend away to Matamba this past weekend and came home via a back road from Vaalwater through the greater Marakele reserve and over Rankins pass into Warmbaths.
    The previous questions I had about the center console getting hot was not an issue this weekend. We had the aircon re-gassed on Thursday and ran it full time on Friday and coming home yesterday. Coming through Hammanskraal area yesterday outside temps were saying 35 but still center console stayed cool to the touch.
    I did however notice the engine temps on the VDO gauge were running slightly warmer than i would normally see yesterday on teh trip home.
    This is the second extended trip since putting the 4.6 in and with a roof top tent and stocked up for a weekend away with groceries etc etc I am averaging around 6.1km/L travelling at 100km/h (measured pump to pump). The nice part however is cruising at 100km/h requires a very light foot and to overtake is no issue, very quickly gets up to 110-120km/h with no hesitating.
    I do sadly have an intermittent misfire that is getting progressively worse - it is a problem that i had on the previous motor so no doubt its electrical or possibly fuel related. When we got home I was fiddling with HT leads and they seemed very loose on the plugs, like there was some play on the connection so i will look at that further.
    Otherwise, this engine just runs so smooth and comfortable, the vehicle is really a pleasure to drive and extremely satisfying up to this point with all the work gone into it.
ID:	595962   Click image for larger version.
ID:	595963   Click image for larger version.
  14. #234
    Thanked: 113
    Jay
    Is that a "baby" roofrack you have in front of the RTT
    looks good though
  15. #235
    Jan 2016
    Golf Park
    Thanked: 224
    Jay
    looks good though
    No it was a roof rack built for the TREK expedition Disco 2s that we picked up secondhand.
    The front of the roof rack follows the contours of the roof
  16. #236
    livingstone
    Thanked: 165
    Hi
    What revs are you running when driving @ 100kmh?
  17. #237
    Thanked: 67
    Matamba is one of my favorite camping spots in SA!
    n' profeet word nie in sy eie land geken nie!
  18. #238
    Jan 2016
    Golf Park
    Thanked: 224
    Hi
    Hi,
    I am not 100% certain. Will be sure to make a note of it next time i take the car out.
    Im thinking around 2500 give or take.
  19. The Following User Says Thank You to Jay_B For This Useful Post:
  20. #239
    Jan 2016
    Golf Park
    Thanked: 224
    Quote Originally Posted by Pottie1 View Post
    Yup for us as well, but i think Booyznkraal has taken top spot for us now.
    Little closer to home and the drive into the river camp adds a sense of excitement and anticipation.
