Plumbing - what would cause an "expansion relief valve" to leak? - Page 2
Page 2 of 2 FirstFirst 1 2
Results 21 to 24 of 24
  1. #21
    Apr 2017
    Durban North
    Thanked: 2298
    Default Re: Plumbing - what would cause an "expansion relief valve" to leak?
    Kwikot will Not ask for proof of purchase,,, there is a lable on the geyser with all the info they need with a code and serial number.
    Here are some examples
    The other Pic is a multivalve that has a shut off
ID:	552503Click image for larger version.
ID:	552504Click image for larger version.
  2. The Following User Says Thank You to Dudleytheplumber For This Useful Post:
  3. #22
    Mar 2019
    Thanked: 25
    Quote Originally Posted by Dudleytheplumber View Post
    Had the same experience. Phone them with the serial number, they allocate a plumber, and it's replaced within a day or 2. No need for a proof of purchase. I was very impressed.
  4. The Following User Says Thank You to El 4 Romeo For This Useful Post:
  5. #23
    Nov 2017
    Strand
    Thanked: 84
    Hello people,
    so i know this is reviving an old thread - but here goes:
    My geyser, for the last ten years (and two geyser replacements in that time, with all components) the Expansion relief valve would drip a bit, specially after a shower.
    it has always behaved this way - new valves and all.
    Now i had a replacement done the weekend past - i have not seen this valve drip once. Do i need to be worried?
    '01 HB DC 3.2D 4X4 (SE)
  6. #24
    Apr 2017
    Durban North
    Thanked: 2298
    This is the life of geyser valves, just when us plumbers have explained to clients why the valves need to drip after use of hot water due to expansion and we carry on da da da... A valve comes along that does not drip.... A few things could cause this,1) is your water on the new installation as hot as it was previously, not as much expansion...
    2)there is a leak some where so expansion is taken care of at the leak.... 3)the safety valve may be leaking...
    But this is not unusual... If its not broken dont try fix it
    Quote Originally Posted by N0ddy View Post
    Hello people,
  7. The Following 2 Users Say Thank You to Dudleytheplumber For This Useful Post:
