Hella plug fitted to engel 40lt
Results 1 to 15 of 15
    May 2007
    Welgelegen, Cape Town
    Thanked: 123
    Default Hella plug fitted to engel 40lt
    I need some help.
    I would like to cut of the cigarrette lighter fitting on the cord for the Engel 40 liter and fit a hella plug, but which wire is positive and which one is the negative?
    I do not have one of these volt meters.
    Thornton
    Can I suggest that you rather make an adaptor , ie cig. socket ,cable & Hella male plug.
    Ford 2.5 2005 4x4 SCab
    roodepoort
    Thanked: 62
    hi johan did your engel not come with an adaptor for the cigarette lighter or the hella plug?
    Thanked: 244
    If you unscrew the cigarette lighter you'll find that it is actually a hella plug. At least mine is.
    2015 Pajero Sport 4x4
    1996 3.5v6 Pajero (For Sale)
    Carpe Diem Scrotum
    Nigel
    Thanked: 1925
    Hella plug is good for about 25A. Lighter nort more than 15A.
    Go the Hella route. The centre pin is positive.
    PS. There are some pirate hella plugs. Don't use them.
    +27 zero eight 2 four 95 9252
    4ePajero Guest
    Hella is a brand name, and they manufacture a wide range of automotive electrical products (including cigarette lighters).
    Their quick connect plug has become known as the "Hella Plug"
    May 2007
    Thanked: 123
    The photograph pasted by 4EPajero is what I am talking about.
    Now if I unscrew the lighter adapter yes it has the three pins.
    So to which Hella Plug does that connect? The one in the photo by 4EPajero?
    Daar is nie plek vir daai connection nie.
    Gadgetman I have made such a connector box you refer to, I must still however connect the hella plug to the Engel cord.
    Nigel
    Thanked: 1925
    Don't use the lighter wires. They are to light. The fuse is usually only 10A. Also it will be dead when you take the key out the ignition.
    Klerksdorp
    Why go for a Hella plug if The Engel only draws MAX 2.8Amp?
    Nigel
    Thanked: 1925
    The cigaret lighter isn't a nice snug fit either. The Hella clips into place.
    Oct 2007
    Krugersdorp
    Thanked: 86
    Johan, I bought a plug at 4x4Megaworld made by Engel espcially for their fridges. The three pins fits in there and the back threaded portion screws into the plug so it will never shake loose.
    KUBU 4X4 TRAILER RENTAL
    083 631 6995
    [email protected]
    www.kubu4x4.co.za
    Click here for the latest updates in the Commercial Section
    Jannie Engelbrecht a.k.a. Granlor
    Oct 2007
    Krugersdorp
    Thanked: 86
    Here's what it looks like:
    Engel Posi-Fit Connection Short Leads
    'Posi-Fit' plug connection is a vibration proof fitting, used for those off road conditions or to connect your Engel to your 24 volt system. Short Cable 30 cm long no switch. Also Available in 4m long cord (APAN) and one model with a built in switch and indicator light (BPAN)
    Product Details: Name: Engel Posi-Fit Connection Short Leads Model No: ASPAN Category: Fridge Accessories Sub-Category: Hard Wire Kits Power: 12 Volt or 24 Volt DC
    083 631 6995
    [email protected]
    www.kubu4x4.co.za
    May 2007
    Thanked: 123
    Dankie Jannie
    4x4 Megaworld Paardeneiland verkoop hulle teen R165.
    May 2007
    Thanked: 123
    Thanks Jannie I bought these cords today.
    One cord is about two meters long, almost the same length as the cord of the Engel.
    I joined these two cords and now have a cord of about four meters or so which will plug into the hella socket.
    Does it matter if this cord is so long or not?
    thanx Henris
    jy's 'n "troof" van inligting
    '08 Hilux 4V6 trailer/roof tent 2 single C-kayaks sb '10 12 xb '10 13 xb '11 9 kites and i love diving
    Speak your mind - those who mind, don't matter. those who matter, don't mind.....
    By charlatan in forum Jeep
  2. How to service your vehicle yourself.
    Last Post: 2015/03/26, 11:43 AM
  3. Engel fridge cord cut to take Hella plug
    By corlius in forum Camping, Fridges, Accessories
    Last Post: 2011/02/10, 09:58 AM
  4. fitting a fridge transit slide lock
    By biltongvreter in forum Camping, Fridges, Accessories
    Last Post: 2009/08/04, 10:10 AM
  5. Amps on Hella Plug
    By Kaptein Jack in forum Camping, Fridges, Accessories
    Last Post: 2008/07/09, 11:38 AM
