Results 1 to 6 of 6
    Mar 2013
    Grabouw
    Thanked: 15
    Default WJ Jeep Transfer case oil replacement
    Good day all.
    Some info.
    I have to replace my Gearbox oil and Transfer case oil as well.
    Mopar ATF +4 for gearbox I Found an replacement at Fuchs Strand : Fuchs Titan ATF 4400
    Mopar Transfer Case Lubricant : Fuchs Agrifarm UTTO MP
    Price difference is significant.
    This is for my Jeep GC 4Lt 2002 model.
    Jeep Grand Cherokee 3.0 CRD WK1 2006
    Jeep Grand Cherokee 4.0 I6 Limited '02 Sold
    2008 2.5 SS 4x4 Mitsubishi Triton Sold
    Jeep Grand Cherokee 4.7 V8 Overland '03 Sold
    Polokwane
    Thanked: 840
    Default Re: WJ Jeep Transfer case oil replacement
    Conqueror Courage 2016
    Polokwane
    Thanked: 840
    I was strongly advised to stick to the original lube for the transfer case.
    For the rest alternatives will do
    Did my diffs, gearbox and trans two week ago.
    Mar 2013
    Grabouw
    Thanked: 15
    Yes, According to different websites they do replace the Mopar transfer case fluid with Mobilfluid 424, the Fuchs Agrifarm are identical to this, I am goiing to be the person trying this out, will let you know what the outcome is.
    Fuchs Agrifarm UTTO MP - R335 vat incl. for 5 Lt against Mopar Transfer Case lube @ R469.85/Lt excl vat
    Fuchs Titan ATF 4400 @ R156.40/Lt vat incl against Mopar ATF +4 @ R290 Excl Vat
    For the Diffs I use Castrol Syntrax
    Sep 2015
    Home
    Thanked: 530
    Quote Originally Posted by bernopunt View Post
    The chap at the Ravenol shop told me the same. Says he has been selling UTTO as a replacement fluid for the QD1 and QD2 transfer cases for quite some time.
    Malpas, UK
    Thanked: 33
    did 150k miles using Mobilfluid 424 in my last WJ with no issues at all, clutches locked up as they should all that time and the fluid showed no sign of clutch wear when changing.
    Steve Wright
    2007 Grand Cherokee CRD Overland
    2020 Renegade Limited S, SWMABO's ride
    Previous Jeeps- 8 XJs, 3 KJs, 3 WJs, 2 TJ's, an MJ & a '17 Renegade
