HELP! Jimny Burning Fuel! 12l/100
Results 1 to 11 of 11
    Nov 2019
    Exclamation HELP! Jimny Burning Fuel! 12l/100
    Hi Guys,
    My Jimny 2011 has recently begun using loads of fuel. The exhaust is black with soet and I can smell the fumes are rich with fuel.
    I have replaced the spark plugs, air filters ect. Nothing seems to be mechanically broken.
    Last year November my catalytic converters gave out and I replaced them with a Van der Graaf freeflow exhaust. Everything was running fine but I started noticing about a two month back that my fuel economy was high. I'm averaging 12L/100. When we replaced it I didnt chip it or have any modification to fix the check engine light.
    Does anyone have any suggestions on what to do?
    joburg
    Thanked: 375
    Default Re: HELP! Jimny Burning Fuel! 12l/100
    Is the car running on closed or open loop conditions when scanned?
    joburg
    Thanked: 375
    On the O2 sensors that is.
    Nov 2019
    how are your revs on iddle? is it high? also what color r tje plugs, are they sooted? do u hear any hissing/sucking in the engine bay wit car running
    if ur high in fuel could be 1) vacuum leak which is easiest fix. then look for other causes such as leaking injectors, compression issues, poor spark, etc
    according to the guy above me, since u deleted cat have u aswell removed o2 sensors? cause without feedback to ECU ur car could be dumping fuel because is not receiving feedback from o2 sensors
    Thanked: 1211
    Daai exhaust.....
    Sent from my iPhone
    Thanked: 10618
    O2 sensors .......
    Oct 2012
    Thanked: 58
    Gaan jou heat guage op as jy na lang ruk gery het en of as motor bitjie gelabour het en jy stop en sit dan af (gewoonlik met fuel stop) ?
    Ek het ook Overfueling issue met dai selfde branch en het catfooler ook in(so geen check engine light). OdbII wys geen errors of snaakse goed vir o2 sensors nie.
    Ek moet nog begin om parte uit te ruil.. (dit kan fuel regulator ook wees wat foutief is)
    You dont need cat foolers on the Jimny , I just removed the inside of my cats and then you bridge the two white wires on the plug of the cat , problem solved and never had issues after that.
    2019 Jimny GLX Manual
    2011 Jimny Zuk-Zilla
    (SOLD)
    GP0057
    Jun 2013
    Quote Originally Posted by Jace View Post
    Hi Guys,
    I had the same problem with mine. I also tried everything.
    It eventually turned out to be a blocked pressure release for the fuel tank.
    Pressure would build up in the tank and cause overfueling. The fuel smell came into the cabin and I had to drive on recirculate to stop it.
    It was a quick fix in the end. Might be worth checking?
    Suzuki Jimny 2015
    Suzuki SJ410 Hardtop 1984
    8)
    Dec 2010
    Durbanville, Cape Town
    airflow sensor on the airbox unplugged?
    Sep 2017
    The Netherlands
    Put a GV sign on it and it is considered normal
