Earthen- cement oven - Page 11
Page 11 of 11 FirstFirst ... 2 3 4 5 6 7 8 9 10 11
Results 201 to 213 of 213
  1. #201
    Richardsbay, KZN
    Thanked: 13227
    Default Re: Earthen- cement oven
    Quote Originally Posted by andrewdjulyan View Post
    Ja it sounds like its not getting enough oxygen at the back there Riaan. I reckon your idea about the baskets will make a big difference.
    Indeed Andrew.
    Walker Evans, Photographer
  2. #202
    Thanked: 13618
    Drill a hole at the back and connect an old hairdryer.........
  3. #203
    Richardsbay, KZN
    Thanked: 13227
    That won't work, the oven needs to ventilate via the bottom of the opening and floor and to the back, wire basket type thing to provide this ventilation is what is needed.
  4. #204
    Richardsbay, KZN
    Thanked: 13227
    As I have these cobblestones for the roof pillars I tried some time ago to use it as a base for the door. The height seems perfect and I can have lazy flames while the door is in place which means it is breathing optimally through the chimney after rolling across the dome.
  5. #205
    Richardsbay, KZN
    Thanked: 13227
    A quick pic from last night, illustrating the smoke from the just started fire seperating from the influx of cold air over the floor. One can see it clearly on the right hand side.
  6. The Following 5 Users Say Thank You to Riaan van Wyk For This Useful Post:
  7. #206
    Richardsbay, KZN
    Thanked: 13227
    The dak is on, but not fixed in place yet. Wasn't going to buy a hole saw to cut one hole so made another plan. The chimney is sealed with foil and a hose clamp for now to see what's what, when I cement the pillars in place I will add gun gum to the joint. Now we can cook in the rain
  8. The Following 4 Users Say Thank You to Riaan van Wyk For This Useful Post:
  9. #207
    Richardsbay, KZN
    Thanked: 13227
    Modified the steel 'stand" in the oven to offer a bit more space to place wood and keep a bit more of it off the floor. I will make a more sturdy scheme at some time as now I know what works. And this works better than my original one.
    You burn, you learn.
ID:	565494   Click image for larger version.
ID:	565495   Click image for larger version.
  10. The Following 3 Users Say Thank You to Riaan van Wyk For This Useful Post:
  11. #208
    Richardsbay, KZN
    Thanked: 13227
    With the modded grid I managed to get three heavy pieces of wood in and it grafts lekker. Goung to try get someone to make me a heavy duty one in the same design sometime.
  12. The Following 3 Users Say Thank You to Riaan van Wyk For This Useful Post:
  13. #209
    Apr 2017
    Durban North
    Thanked: 1802
    Where did you get that wood?
  14. #210
    Richardsbay, KZN
    Thanked: 13227
    Quote Originally Posted by Dudleytheplumber View Post
    Local petrol filling station Dudley, still trying to ID it but it seems like from the Leopard tree. Burns very well and hot.
  15. #211
    Richardsbay, KZN
    Thanked: 13227
    The wood on the frame in the other pic is acacia.
  16. #212
    Mar 2013
    Thanked: 35
    Hi Riaan. Would like to make you n grid jobbie, but I think postage from Gauteng might be expensive.Just read through your latest braai related threads and really like your setup(s). Inspired by one of your posts long ago, I packed a braai on my lawn that consists entirely of bricks. Works like a charm and I can modify it depending on if I am having a normal braai, staanrib, potjie or what ever my heart desires.
    2008 KB300 D-TEQ 4x2
  17. The Following User Says Thank You to Namakwalander For This Useful Post:
  18. #213
    Richardsbay, KZN
    Thanked: 13227
    Quote Originally Posted by Namakwalander View Post
    Awesome Namakwa, glad I can inspire someone.
  19. The Following User Says Thank You to Riaan van Wyk For This Useful Post:
