4by4 wont disengage?
Results 1 to 5 of 5
    Default 4by4 wont disengage?
    Drive an old v6 manual 4by4 (with the leavers) , went down sani this week in low 1 gear mostly then high 4 the rest, get to customs and it does not want to disengage, after trying a few times, I put it in reverse and that seemed to work.
    Should I be worried? What do I need to do? Please help?
    Our Travel and Photography blog- https://twotracks.co.za
    The Beast - 2005 Toyota Hilux D/C 4L with freeflow
    Daily Drive- Girlfriends Honda Jazz
    joburg
    Default Re: 4by4 wont disengage?
    Quite normal
    Ruimsig
    Yip, it can be normal. My Disco 1 v8 would often do the same and reversing and ''unwinding'' the diffs would clear it. It was recommended practice in one of the handbooks to reverse a number of meters after using the CDL.
    Quite normal.
    Thank you very much guys! Big relief!
