Lifting a 2018 Ford Ranger "Low Rider"
Results 1 to 19 of 19
    Nov 2019
    Question Lifting a 2018 Ford Ranger "Low Rider"
    Hi everyone,
    I'm new here.. Just bought my first Ranger.
    (If this is the wrong section to post this, please feel free to move it or if you have to, delete it).
    I've decided to try lift my bakkie in an attempt to make it a little less "contractor looking". haha. I'll be putting on some nicer wheels and obviously tires too at a later stage.
    For now however, I've been looking into the lift kits. I've been told that I can't actually lift the "low-rider" version that I have - however I haven't been able to find much mention of this "low-rider" model... Has anyone had any experience with this? Or can maybe point me in the right direction?
    And while I'm here - I'm looking for a rear bumper too that won't hurt the bank too much (been quoted R7k so far).
    Thanks so much!
    Pennington
    Thanked: 168
    Default Re: Lifting a 2018 Ford Ranger "Low Rider"
    With regards to the rear bumper. Keep looking on Gumtree or even easier phone aftermarket bumper fitment shop as they are always looking to get rid of them.
    Thanked: 14155
    bigger tyres will immediately lift the general stance, just be careful about the width because without a suspension lift, there is chance they will rub somewhere
    Front suspension: not much you can do there, if the bakkie has coils, you can go for a coil spacer, or else if it is torsion bars, they can be tightened up a little
    Rear suspension: two options, first is longer leaf spring shackles, second is a Spring Over Axle conversion
    Pennington
    Thanked: 168
    Front is coil over shock. You can fit a 255/70x 16 tyres but they drain the power, and the speedo is way out. A better option is a 235/70x 16. This is if your base model is fitted with 215 tyres currently. The 255 do not rub even when the vehicle is loaded at gvm
    Nov 2019
    Quote Originally Posted by mplester View Post
    Awesome, thanks. So if they are coil over shocks, can I do what Jelo says and get spacers? If so, any ideas where? I've tried Safari and a few other 4x4 places.. no luck.
    Also, is there a reason you're sticking with 16" wheels? The guys at Tiger Wheel & Tire reckon I can go up to 17" without any problems - it also means more tires are available (apparently)
    Thanked: 14155
    Quote Originally Posted by byroncoetsee View Post
    Spacers: poly plastic can work.
    Why change wheels? PLENTY 16" options.............TWAT are clueless.
    Dec 2010
    Durbanville, CPT
    Thanked: 143
    https://bakkiebarking.co.za/catalogs...esult//?q=lift
    They are in Strand, so not that far away from you.
    2016 Ford Ranger XL DC 4x4 - Die kar agter die donkie
    2009 Mitsubishi Triton DC 4x2 - Sold
    2005 Mitsubishi Colt 2.4 DC 4x2 - Sold
    Pennington
    Thanked: 168
    16 inch are easy to get anywhere in the country. They are also cheaper.
    Jul 2017
    Thanked: 145
    Stick with 16 and go 265 70 16. Works great on my Ranger and I have the old one, so you should be fine. 16 inch will give you a nice profile size.
    Regarding a lift, if it's pure cosmetics your after then do a spacer lift in front and extended shackles or add a leaf spring in the rear.
    Please view this ad:
    https://www.gumtree.co.za/a-car-acce...nt=app_android
    It's not gonna do anything for handling or off road but it will raise the car up.
    2008 Ford Ranger 3.0 XLT 4x4
    Nov 2019
    Quote Originally Posted by Walnut View Post
    Great, thanks. Would 265 not be too much for a low-rider? (that always makes me think of those gangsters with hydraulic shocks and gold rims.. haha)
    I'm looking to put spacers in from Bakkie Barking... They're "90% sure" it will work on the low-rider.
    Jul 2017
    Thanked: 145
    Spacers will only work in the front, the rear is leaf springs so you will need to add extension shackles.
    I don't know about low rider but test fit it and see.
    Anyone with a D4D Fortuner will have that size.
    Pennington
    Thanked: 168
    I have the same spec vehicle and a 255 just clears. But it's a big power drain
    Jul 2017
    Thanked: 145
    What engine is it? I have the old 3.0 TDCI and I can't see any difference. The Speedo even runs more true.
    Nov 2019
    Mines a 2.2 TDCi ... Seems to have quite a bit of torque
    Pennington
    Thanked: 168
    What is your std size tyre as mine had 215/70x16
    Nov 2019
    Yeah thats mine too currently.
    Pennington
    Thanked: 168
    Ok 235 works well. Speedo very accurate. 255 you notice a loss of performance and speedo under reads which is not ideal. 100 on the clock is 108 true. 15000 service interval is 16350km true.
    Thanked: 14155
    215/70-16 = 707mm diam
    235/85-16 = 806mm diam
    12% difference in diameter.
    4 inches.
    That means an immediate 2 inch lift for the price of a set of tyres. More than 265/70-16 can offer and thinner so less rolling resistance. Also cheaper.
    Nov 2019
    Ah maths. I was waiting for this to get mathematical. haha
    I think the 235 is the way to go... I'll also be adding spacers and shackles in from Bakkie Barking (when they respond - I'm just getting blue ticks now on whatsapp...)
    Regarding the incorrect odo reading - great for resale value 😅
