270 awning
Results 1 to 14 of 14
Thread: 270 awning
    Aug 2018
    Paarl
    Default 270 awning
    Ek probeer uitvind my wa het op die oomblik n l shape awning op wat uitrol en vas velcro aanmekaar.
    Die L shape awning is 2m van my wa tot op awni g einde as opgeslaan is.
    As ek n 270 awning wil opsit wat om en by dieselfde area gee wat moet die lengte van die awning wees.
    gansbaai
    Default Re: 270 awning
    kontak danie hayman in malmesbury van hd manufacturing.(se donadio jou verwys)
    hy maak 270 awnings van uitstekende gehalte.
    ripstop en stainless steel frame
    083 265 5299
    2004 3.0 KZTE LEGEND 35
    Melkbosstrand
    Quote Originally Posted by fatbike View Post
    You don't say what van you have... but here goes...
    I've got this fitted to my Companion (the 2.45m version), and as you can see, it sticks out 2.3m from the van. The front is a bigger area, buy you lose the corner (bottom right of pic) so the area is much over muchness
    hope this helps
    Last edited by BobMabena; 2019/11/21 at 11:54 AM. Reason: was wrong about the area
    2015 VW Amarok 4motion Auto
    2011 Conqueror Companion
    Aug 2018
    Paarl
    Quote Originally Posted by BobMabena View Post
    hope this helps
    What awning do you have and is the green block your van so awning is 2.45m in length.
    Melkbosstrand
    Yes, that's right.
    I've got the BunduTec BunduAwn...
    Brackenfell
    Fatbike - sien jy in Paarl WC. Stuur pm na SAUK hier op die forum. Dis Renier van Shorty's adventure. Hy kan jou dalk ook goeie inligting/raad bied.
    Dalk custom bou ook.
    Aug 2018
    Paarl
    The 2.3 x2.3x 2.3x2.3 block is that an xtra add on
    I have not seen that on the bundu tec before.
    Melkbosstrand
    They have 2 versions of the 270 awning...
    That pic is of the "squareback", I've got the regular version, but then had the additional triangle added as a removable section, that I only use when I set up the sides.
    Aug 2018
    Paarl
    Hi do you maybe have a pic of awning pitched and price on that one(square back)
    Melkbosstrand
    No clue on the price I'm afraid...
    Also, don't really have any good pics of it pitched... only this
    I have the old Echo ChobeII with the older 270 Ostrich Wing Awning (think it is from Big country).
    I bought the trailer with the awning already fitted and it is aprox 2.4m mounted on the side and when open it is aprox 2.2m
    It feels very solidly mounted and very strong structure. I have been in some heavy wind storms where the awning worked well (even with the side panels mounted) if the poles are set down and pegged in.
    I do however get some water "puddling" and have made some plans to address most of it but I still need to keep an eye on it.
    I am also considering the bundutec Awning for the 360 coverage, mainly to cover the front pull out kitchen slide that does not get covered by the 270 awning.
    I am just worried for the strength of the bundutec if it will standup the heavy winds that accompany some the Thunderstorms we get when camping/fishing at the dam with large open areas and no shelter from the wind.
    Will be great to hear from anybody on how the bundutec bunduawn holds up in storms with or without side panels.
    Aug 2018
    Paarl
    Quote Originally Posted by Libdoo View Post
    Hi can you maybe send some pics of your awning especially how it is mounted on your van.
    Cell. 0826127120
    Here are some pictures
Name:	front view1.jpg
Name:	Rear mounting1.jpg
Name:	Rear mount2.jpg
Name:	swing connector2.jpg
Name:	front mount.jpg
Name:	front overhang.jpg
    Aug 2018
    Paarl
    Please share more info regarding that pull out drawer you have.
