Whats the best LDV/bakkie engine on the market now?
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 54
    Postmasburg
    Default Whats the best LDV/bakkie engine on the market now?
    Ive been thinking of what might be the best engine for workhorse/double cab now on the market.
    The criteria is simple:
    It must be durable/reliable.
    It must be economical.
    Parts must be easy to source.
    I must have enough power to overtake a vehicle going 110kph safely.
    It must be available in a workhorse, meaning that although BM and Merc make GREAT diesel motors, they dont qualify for this.
    It must be diesel.
    What would you guys say? It must be currently available.
    Lots of engine would tick some of the boxes(like the 1HZ, but it loses out on power and economy.
    Shoot...
    Default Re: Whats the best LDV/bakkie engine on the market now?
    One vote for the Isuzu 4JJ.
    Bethlehem
    Ek dink die Hilux 2,4 GD 6 is ook goeie enjin, en ook die Workhorse 2,4 GD "s" of so iets?? Dis die down tuned 2,4.
    Isuzu ook maar altyd goed.
    Jy wil 'n worhorse maar ook 'n DC he......wat wil jy doen met die Voertuig, wat is sy "intended use"??
    Of COURSE I have a Bad Habit. I take Tea at Three (Mick Jagger)
    Postmasburg
    Petrie, ek dink maar net aan werksbakkie enjins. Jy kry hulle gewoonlik in DC en SC. Dit is hoekom ek vra.
    Die 2.4 Toyota enjin is mos dieselfde, of hy nou in die platbakkie of die SRX is, dit bly selfde enjin?
    Dit dalk rede hoekom daardie platbakkies so lekker hardloop.
    Bethlehem
    Nee, die 2,4 in die plat Lux is baie ge "down tune" as die een in die SRX. Nou nie syfers in my kop nie maar redelik. Maar daai papper 2,4 voel of 'n miljoen gaan doen.......
    Gaborone, Botswana
    Nissan YD25
    Kobus
    Nissan
    Kathu
    2.8GD6 and you will still see 10 to 11km/l at 120.
    Mar 2015
    Isuzu 4JK gets my vote
    Jun 2016
    Randfontein
    Isuzu KB250.
    2016 Audi A3 1.8 TFSI SE S-Tronic 3Dr
    OK, have you factored the ECU in? How are you going to do engine management on one of these without a cracked OEM ECU?
    Do you have the electronics background to be able to use an OEM ECU and provide all the inputs needed.
    If not, are you then narrowing your choice to a simpler old school ECU (minimal inputs) or even non-ECU?
    What is your target kW and Nm? What weight is your target vehicle?
    Postmasburg
    Jelo, no rebuildt or transplant.
    Net n betroubare engine soos uit fabriek.
    Hierdie is maar net een van daardie lekker gesels drade oor hoekom enjin goed is en watter een.
    bv, mens hoor nie van Isuzu 4jj/jk enjins wat breek nie, maar ek verstaan om hulle oor te bou kan baie duur wees.
    Quote Originally Posted by Mapog View Post
    OK, my mening:
    Old school (importers only):
    Isuzu 4JB1T
    Isuzu 4JG2T
    Nissan TD27T
    Nissan TD42T
    Nissan RD28T
    New school:
    Nissan YD25
    Isuzu 4JJ1
    I would go Toyota 2.4 GD6 or the Isuzu KB250 but I think next year Isuzu's new 1.9 is going to be a winner.
    FJC - Just Cruising
    Nissan TD27QD32 and QD32TiFord WL25
    Nato
    '13 Nissan Navara 2.5TDCI DC 4X4
    Ex '08 Nissan Hardbody 3.0 TD 4x4
    Ellisras
    What about the 3.0TDI as in the latest Patrol Pickup.
    2000 Patrol GU 4.2D(onkey) beyond 844 000 km
    2014 Patrol GU 3.0CRD
    Constantia Kloof
    I would put the 75KW Austrian AVL 2.5L TD engine as found in the Mahindra Bolero and older generation Pik Up up there with any other mechanically injected TD in terms of durability. The same engine with common rail injection and uprated power/ torque figures does service in the Thar
    Likewise I have been massively impressed by the 104KW 2.2 Mahindra MHawk engine in my current vehicle and have not read or heard any horror stories about reliability on these units. This engine is very smooth and quiet, gives good economy and pulls hard from low RPM.
    Both these engines have been in production for quite some time with the MHawk having been refined continuously since the original 80 odd KW units came out more than 10 years ago.
    Longevity of an engine is dependent on more than just the brand. I don't think there are many poorly designed light commercial diesel engines still on the market today, I do think many of the so-called issues one hears about are user caused, either through abuse or negligence when it comes to maintenance.
    2007 Mercedes Benz ML500 5.5
    1968 VW Beetle 2276
    Jan 2016
    'n Diesel mechanic het onlangs sonder om te twyfel vir my ges Isuzu.
    2001 Gen 3 Pajero swb 3.2 Di-D
    Postmasburg
    Ek moet se ek is nogal hewig beindruk met my GD2.8. Gee baie goeie verbruik, maar slegs 40k km op huidiglik.
    Die ander twee is die Isuzu 2.5 en 3.0 enjins( selfde enjin, een net groter?)
    Dan soos genoem bleik die YD2.5 Nissan ook goed te wees.
    Postmasburg
    Min manne praat van Ford?
    MAKLIKSTE IS SEKER DEF DIE MEGANIESE ISUZU ENGINE. MAAR OOR SEE(JEEP) EN HIER(CRUISERS)(https://www.helberconversions.co.za) SIEN EN MANNE GEBRUIK NOU BAIE DIE CUMMINS 2.8ISF SOOS IN MY BAKKIE. (CRATED ENGINE). Baie reliable engine.
    FOTON TUNLAND 4X4 LUX
