Help me - Alternative to 265/70/16 Size??
Results 1 to 20 of 35
    Bethlehem
    Thanked: 3642
    Default Help me - Alternative to 265/70/16 Size??
    Looking at a higher tyre for my Patrol. It can even be a tad narrower too.
    Currently has 265/70/16 on it.
    What alternative sizes can I look at?? Like I said, higher, and either the same width or even a tad narrower.
    The car's wheel arches still have plenty room, so I'm 99% sure a taller tyre wo'nt rub.
    THANKS
    Of COURSE I have a Bad Habit. I take Tea at Three (Mick Jagger)
    Jan 2011
    Thanked: 595
    Default Re: Help me - Alternative to 265/70/16 Size??
    Cool, I also need an alternative for my Wrangler for the same size tyre.
    Before you criticize someone, you should walk a mile in their shoes.
    That way, when you criticize them, you're a mile away and you have their shoes.
    Okahandja, Windhoek
    Thanked: 791
    .................Dia Circ
    265 70 16 777.4 2441
    235 85 16 805.9 2531
    265 75 16 803.9 2524
    255 85 16 839.9 2637
    285 75 16 833.9 2618
    Johan Kriel
    LCs, Hilux and Echo Chobe
    Thanked: 1521
    Put on a good old 235/85R16
    Larger rolling diameter. You will not be sorry.
    They are also almost universally LT spec.
    1999 Discovery 1, 300 Tdi - "Tink Tanky"
    2004 Discovery 2 Td5 - "Blink Tanky"
    "...it is abundantly clear that you are an arrogant C-nut." - Estee. (I was overwhelmed. It was the nicest thing someone has said to me in a week!)
    Jan 2011
    Thanked: 595
    Does anyone know these tyres? For the price I'm a bit careful.
    https://www.fundityres.co.za/205-80r...ber-tr-xl-104t
    Bethlehem
    Thanked: 3642
    Quote Originally Posted by biltong View Post
    Biltong, that's my all time favourite size!! BUT will it work?? Errols Tyres have some "calculator", that says no go.
    THANKS Guys
    Bethlehem
    Thanked: 3642
    Johan....praat staaaaaaarrag met my , asb
    Die 255/85, is hy breer as die 235/85? Of selfs dan die 255/85....?? My favourite is 235's, maar hulle gaan nogal kwaai "wegraak" in wydte op die Patrol se whee; arches dink ek. Gaan soos 'n UN Patrol lyk (ook nie so bad gedagte nie mind you...........)
    Okahandja, Windhoek
    Thanked: 791
    Ja 285 is breer (+-285mm). 235/85 is amper n marie biscuit. 255/85 is net bietjie smaller en heelwat dieper profiel. Hang af hoekom jy dit will doen. Ek sou net n 265/75 opsit.
    Johan Kriel
    Bethlehem
    Thanked: 3642
    Johan, die Trol staan vir my "laag", ek sal like van so bietjie hoer tyre.
    Use gaan wees grondpad/teerpad/klippe/modder.
    Ja daai 235 is mos maar amper 'n 7.50 x 16?? Hy gaan rerig wegraak in daai wheel arches.
    Verskil in hoogte tussen die 255/85 en die 265/75??
    Thanks , waardeer julle raad BAIE.
    May 2011
    Thanked: 973
    Petri. Gaan speel op die webblad.
    https://tiresize.com/calculator/
    Gaan na comparison
    Gaborone, Botswana
    Thanked: 1048
    Kobus
    Bethlehem
    Thanked: 3642
    Kobus/Luka............VERY helpful links thanks!!!
    Okahandja, Windhoek
    Thanked: 791
    J
    255/85 is 30mm groter in Diameter. Klink my dis wat jy soek? Jan Slabber ry hulle onder sy bakkies.
    Johan Kriel
    Bethlehem
    Thanked: 3642
    Johan, as ek hierdie calculator gebruik..............https://tiresize.com/calculator/
    Dan is die verskil tussen my current 265/70 en 255/85 60mm, of 6 cm hoer..........
    Skuus al die vrae, eks dom met die goed.
    May 2011
    Thanked: 973
    Is dit die deursnee? Dan is dit 60mm / 2 dus 30mm
    Thanked: 1521
    Meneer, soek jy 'n taaier wat kan lyk of wat kan werk?
    Die 235/85 is nie so baie maer nie, en jy gaan die Patrollie met amper 30mm lig.
    As jy grip soek, dan doen jy roldiameter voor wydte.
    Thanked: 1521
    In deursnit ja. Ek laik van hoer taaiers. Dalk sal 'n Hangkoek dit vir jou doen?
    Bethlehem
    Thanked: 3642
    Ek dink die 255/85 kan 'n nice "golden midway" wees. Het so paar karre hier met 16's, sal gou kyk en meet en met die Trol se bestaande tyres vergelyk.
    Iemand gaan 'n 79 Cruiser koop wat so bietjie platter staan as gister...............
  19. #19
    Okahandja, Windhoek
    Thanked: 791
    daai calculator is reg: band deursnit ; 265 x .7 x 2 + 16 x 25.4 = 777mm , calculator = 777mm
    255 x .85 x 2 + 16 x 25.4 = 839.9 mm, calculater = 841mm
    Verskil is 64 mm , grondvryhoogte die helfte van dit.
    Johan Kriel
  20. #20
    Thanked: 1521
    daai calculator is reg: band deursnit ; 265 x .75 x 2 + 16 x 25.4 = 803.9mm , calculator = 803mm
    Verskil is 37 mm , grondvryhoogte die helfte van dit.
    Dis 265x70
