Discovery 2: Is this a welsh plug leaking?
Results 1 to 17 of 17
    Jan 2018
    Waterfall
    Default Is this a welsh plug leaking?
    Its time...
    1999 Mitsubishi Pajero 3500 GLS 24v V6 GROWING ON ME
    2004 Discovery 2 TD5 Auto 226000km SOLD KINDA MISSED
    2008 Freelander 2.2 SE SOLD MISSED
    2013 BMW F800 GS SOLD MISSED
    2005 FORD RANGER 2.5 TD DOUBLE CAB SOLD
    2016 SPECIALISED CAMBER CARBON COMP 29er
    Oct 2019
    Karoo
    Thanked: 362
    Default Re: Is this a welsh plug leaking?
    Quote Originally Posted by Ryanie View Post
    Its not a welsh plug.
    Its a plug that screws in and out sealing on a copper washer.
    I cant see a leak in the picture.
    (Welsh plugs sit in a engine block and cylinder head, those round things that look like a cup.)
    I am not familiar with your engine having never worked on it however Im sure someone will point you in the correct direction.
    Do you think its leaking oil or coolant?
    Thanked: 485
    That is not a welsh plug.
    Rand for Rand gets 33Km/L
    Oct 2015
    Thanked: 68
    Which landrover is this pic from...year as well? Why do you think your Irish plug is leaking?
    Discovery Landrover 3 tdv6 2008
    Volvo S40 T5 2006
    Thanked: 475
    Just behind the alternator under the exhaust is a silver plug.
    That a welsh plug.
    WELCH nogal
    Defender Kalahari
    Series 3 SWB
    Series 2 SWB (Near Future)
    Series 1 Station Wagon 88''
    Jan 2018
    Waterfall
    [QUOTE=Craigin;4271103]Its not a welsh plug.
    I cleaned up the area and found an oil drop coming from there. I have a leak in this area and Im trying to find the source. Not sure if its oil or steering fluid. Appears to be oil as it is slightly dirty. Will keep checking.
    There is also oil/fluid being sprayed in a fine mist across battery box and pipes. Also oil from the large pipe into EGR blank.
    Its time...
    Jan 2018
    Waterfall
    Quote Originally Posted by Shade View Post
    2004 Disco Td5. P10
    Its time...
    Oct 2019
    Karoo
    Thanked: 362
    @ Ryan
    As said before I dont know that engine, I stand to be corrected on what I mention below.
    Power steering leak should be ATF oil = colour red.
    Engine oil = mostly dark colour.
    Bear in mind whilst driving and the action from the radiator fan pushes all leaks to the rear end of the engine.
    Try get a engine manual to identify exactly what you are looking at.
    Feb 2012
    Thanked: 63
    Check the pipe just above. Could be the culprit.
    It has a small O-ring on the pipe just ahead of the nut. (When removed make sure it is not stuck inthe hole)
    The O-ring goes hard and could leak. IIRC this pipe is a feed from the alternator vacuum pump.
    The other blank plug uses normal copper washer.
    The radiator fan then blows oil all over the place.
    Oil will be blackish (Engine Oil)
    Gary W
    Discovery 2 (Td5) Best 4x4xfar
    BMW GS 1200 Adventure. For when the road ends...
    Jurgens XT120..home away from home.
    Thanked: 867
    Is that not the hydraulic tensioner for the timing chain? If it's not tight or the copper washer is not flush it will leak oil...
    Jan 2018
    Waterfall
    Quote Originally Posted by Tsotsi View Post
    Thanks Gary. I will check the pipe above and the o ring.
    Its time...
    Jun 2016
    Randfontein
    Thanked: 1575
    Yes your'e right thats the tensioner bolt for the timing chain. I just checked on my TD5. I also see its right above the injector harnass plug. Oil might be coming from there as well.
    Willie
    2016 Audi A3 1.8 TFSI SE S-Tronic 3Dr
    Zululand
    Thanked: 76
    If the tensioner nut has been removed before the copper washer will be hard. ( work hardens) , and will leak. You can anneal it by removing it and holding it over a gas torch with a long nose plier. Until it turns red, then remove and cool naturally. Washer will now be soft and re seal
    Ruimsig
    Thanked: 6366
    Welch Plugs are force fitted into a block to seal channels and will leak if corroded, which can be prevented by ensuring sufficient anti-freeze is maintained in the engine.
    Those washers are normally replaced if loosened off. See if there is a torque setting for it as it might not have been replaced at the correct setting. Pinching it up to the correct torque could help if it is the cause of the leak.
    Estee = S T = Sean Towlson
    2010 Hummer H3 5.3lt V8, 300 HP, FDL, RDL, CDL, TC and 4:1 Low Range Building for Touring, not Trails
    FJ: One day when I am big
    Land Rovers: Done unfortunately
    Jan 2018
    Waterfall
    Quote Originally Posted by Andrew D View Post
    Thanks Andrew this is good!
    Its time...
    Springs
    Thanked: 277
    the tensioner washer should ideally be replaced with a Dowty washer. it seals better and lasts longer.
    problem is that if you have a leak there, oil is likely to drop into the alternator and sooner than later the alternator will pack up.
    there are 3 welsh plugs on the driver side of the engine and typically you need to remove the diesel cooler as well as the engine mounting and bracket to get to them. for sure if your welsh plugs are stuffed, i guarantee you the oil cooler if stuffed as well. welsh plugs fail due to poor upkeep of the cooling system. people will scream blue murder contemplating whther to use semi or full synthetic oi, whether to use Castrol Magnatec or LiquiMoly or Shell but they will be totally ignorant to the basics of proper cooling system care.
    Jan 2018
    Waterfall
    Quote Originally Posted by Landyluvver View Post
    Thanks LL
    Will check for Dowty Washer
    Its time...
