Rubber Mats/Flooring in 110 - What is Nice??
Results 1 to 13 of 13
    Bethlehem
    Thanked: 4229
    Default Rubber Mats/Flooring in 110 - What is Nice??
    I'm looking at rubber mats in the 110, 2 x Fronts, the rear footwell, and then the rearmost loadbay (no jump seats).
    What works nice in these??
    I would also VERY much like a sort of felt/softer rubber underneath to help with dampening/heat.
    .........Or do I just get nice thick rubber at Pro Auto Rubber tomorrow when in GP, and stick some "hikers mattress" padding underneath that??
    Must also be resaonably non slip for the dog/cooler/fuel tanks for the offroads.
    THANKS
    2008 Mercedes Benz CL 500........................"Bullet"
    2006 Mercedes Benz C 180K........................"Sussie"[/COLOR]
    Sandton
    Thanked: 126
    Default Re: Rubber Mats/Flooring in 110 - What is Nice??
    dynamat or sound dampening film underneath the car in those areas - shiny bits facing the bits that causes the heat
    Sondor thick foam/ rubber inside - if i remember correctly they had a 15mm or 25mm thick rubber matt - they will advise best which one of their products will be suited.
    Defender RAW Nara Bronze
    Series III 88
    VW Caravelle (wife)
    KX450F #78
    KX 65 # 10
    handmadeprojects.co.za
    Sep 2014
    Little Falls
    Thanked: 131
    Astroturf....
    I've had it in my truck for years, and it's awesome.
    Traps dirty, easy to wash, and fantastic under bare feet when driving.
  4. The Following User Says Thank You to MudMuppet For This Useful Post:
    Bethlehem
    Thanked: 4229
    Anyone uses "Afriboot" Products?? Also looks nice, and I like the "edges" , will help keep dirt out.
    www.afriboot.co.za
    Sep 2014
    Little Falls
    Thanked: 131
    Even the mutts love it
  7. The Following 2 Users Say Thank You to MudMuppet For This Useful Post:
    Bethlehem
    Thanked: 4229
    Quote Originally Posted by MudMuppet View Post
    Astroturf....
    DAMN nice idea that, Muppet...........THANKS
  9. The Following User Says Thank You to Petri Oosthuizen For This Useful Post:
  10. #7
    Bethlehem
    Thanked: 4229
    Muppet that would also work 200% for heat issues inside the cabbie I think, used as a sort of "underfelt". And no small stuff rolling around if used without a "top mat".
  11. #8
    Sep 2014
    Little Falls
    Thanked: 131
    Net ń plesier meneer!
  12. #9
    Sep 2014
    Little Falls
    Thanked: 131
    I find it nice and cool, regardless of the time spent driving Petri.
    I'm almost always barefoot in the Landy, and I honestly cannot recall my feet ever getting hot.
  13. #10
    May 2010
    Thanked: 159
    THANKS
    Pro Auto also have various thicknesses of the "hickers mattress" you are looking for
  14. The Following User Says Thank You to Ejay For This Useful Post:
  15. #11
    Bethlehem
    Thanked: 4229
    Just bought a set of mats at www.afriboot.co.za
    Looks like decent quality.
    Muppet I'm still gonna do your thing at the rear, sounds like a great idea.
    Not the bargain of the Century at R 3375 for the full set (2 fronts, middle, rearload area) but the afriboot looks OK, and I'm gatvol for this place, need to go home, so hoping for the best.
  16. The Following User Says Thank You to Petri Oosthuizen For This Useful Post:
  17. #12
    Bethlehem
    Thanked: 4229
    Fitted............not too bad I think.
ID:	546200   Click image for larger version.
ID:	546201   Click image for larger version.
ID:	546202   Click image for larger version.
  18. #13
    Robertson/ Larissa, Greece
    Thanked: 3086
    Not too bad? Ek dink dit lyk blerrie goed!
  19. The Following User Says Thank You to Francois Theron For This Useful Post:
