I need some direction....pleeeeeeeeeease!
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 51
    Jul 2019
    JHB
    Default I need some direction....pleeeeeeeeeease!
    I do things a little ass about face:
    I bought a second hand Engel 40l fridge.
    Once I had the fridge I figured I may need to power it without running my car battery flat, so I put in a dual battery system (WRND dc/dc charger) and because it was solar ready, I put a panel on the canopy roof (after some great advice on this forum)
    My fridge has been using the sun to keep my beer cold for the last 3 weeks constantly. Between running the car to work and parking in the sun to charge the second battery when I'm at work, my beer is so cold my mouth is watering while I'm typing this.
    Until yesterday!
    Yesterday I went to the car, checked that the panel had my battery float charging at 13.7v but the interior temp of the fridge was 26 Degrees C.
    I checked all the connections from battery to fridge. All ok.
    I checked the fuse in the fridge. Ok.
    I checked that I had 13.6v going in to the fridge with a multi meter.
    I checked that the cable from battery to fridge was not broken.
    I have no idea what to check now?
    Where to take it to?
    Will I be ripped off?
    Today is a really sad day :-(
    The beer is warm and I now have a R4k hot box in the back of the bakkie.
    King Williams Town
    Default Re: I need some direction....pleeeeeeeeeease!
    How much is a new fridge of same capacity and make.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
    Jul 2019
    JHB
    It seems around R9500 for a new 40l
    Polokwane
    Can you hear the compressor running?
    2 scenarios:
    Fridge is stuffed. Fix it.
    Internal Fuse has blown. Fix it.
    Jul 2019
    JHB
    Nope, the power light doesn't come on and the compressor isn't running.
    Jul 2019
    JHB
    2 scenarios:
    Where does one send a stuffed fridge to fix it?
    Any direction as to where to find the internal fuse, or should I just open the guy up and take a look?
    Fanks :-D
    Quote Originally Posted by MAG69 View Post
    Fanks :-D
    4x4MegaWorld can fix. But it will cost a lot.
    Jul 2019
    JHB
    Thanks Jelo
    Any chance there's an alternative to 4x4MegaWorld?
    It's not like it's under any warranty or anything :-(
    Apr 2019
    Does the fridge work on both AC and DC via separate plugs? If so have you tried both?
    Jul 2019
    JHB
    It does work on both. Separate plugs. I haven't tried on mains yet. I'll give that a shot.
    Thanks.
    Thanks Jelo
    based on a multitude of previous threads on this, the only alternative is a different compressor
    This forum member apparently knows how:
    https://www.4x4community.co.za/forum...p/3201-JohannP
    Ruimsig
    Before taking it in and incurring the expense and since it was a used unit, I would suggest opening it up and using your multimeter to do some tests.
    You know that you have power going in so start there
    Estee = S T = Sean Towlson
    2010 Hummer H3 5.3lt V8, 300 HP, FDL, RDL, CDL, TC and 4:1 Low Range Building for Touring, not Trails
    FJ: One day when I am big
    Land Rovers: Done unfortunately
    Sasolburg
    I would think that it's a fuse. It has a fuse outside at the power input. Is there an internal fuse as well?
    If the light came on and it did not cool then I would be worried. This sounds like an electrical supply problem. Hope you get it sorted.
    If Force is not the solution, not enough of it was applied....
    Does the power get to the fridge. Unplug the cable on the fridge and measure there.
    My biggest gripe with that Engel is the lack of low voltage protection. It will gladly run the power down to 7V and then burn the motor.
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
    Mar 2007
    Harties Boet
    Test it on the mains plug first as has been mentioned
    2004 Nissan Patrol 4.8
    1999 Nissan Patrol 4.2D
    Polokwane
    Probably a power supply issue.
    Follow advice already mention.
    Johan on the Forum is your guy if you don't come right.
    These fridges are very robust, I doubt is something serious.
    Jul 2019
    JHB
    Hi Uys
    Yip, if I measure where the socket meets the fridge, it has power reaching the fridge.
    I'm hoping it has an internal fuse and that has gone just from wear and tare. The outside fuse at the back of the fridge is fine.
    Jul 2019
    JHB
    Thanks so much.
    I really hope you're right that it's not something serious.
    Apr 2019
    Hi Uys
    maybe something just downstream from the fuse holder...
