to drill or not to drill
Results 1 to 3 of 3
    Malmesbury
    Thanked: 119
    Default to drill or not to drill
    i made these brackets to fit on the colt and a roof rack fitted on it ,the previous hold fast tipe bracket came loose ,with these ,only the bracket stays on the colt the rest will be dismantled and stored away after a trip.
    now i am thinking, will m8 rivnuts fitted in the rain gutter work or drill the holes and fit a plate under the roof and bolt it ,the roof rack will only be used to carry 2 jerry cans and a spare wheel for my trip to namibia
ID:	545558   Click image for larger version.
ID:	545559   Click image for larger version.
    Colt clubcab 2.8tdi 4x4 2005
    Ford Fiesta 1.4i (SWAMBO]
    opel corsa 1.7 dti 2006
    Jul 2018
    Durban Hillcrest
    Thanked: 40
    Default Re: to drill or not to drill
    Does the track not have a slider in it that already has a thread that you can bolt into.
    Malmesbury
    Thanked: 119
    the roof rack fits on the cross alu rail and fits on the stainless brackets and then fasten on the bracket i made ,the bracket i made must be fasten in the gutter ,
