Defender Td5 external fuel pump alternative
Results 1 to 14 of 14
    Sep 2019
    Default Td5 external fuel pump alternative
    Hi All,
    Having owned two td5's, both of which have had failed fuel pumps, I am getting a little fed up with their reliability. I would like to place an external in-line fuel pump mounted on the chassis, I am thinking where the current fuel filter is. To do this my plans are to rip out the current pump, and remove the LP system. I will fit an aftermarket HP pre and post pump filter. The end system will be a direct line from the tank to the pump, which sends HP fuel to the fuel regulator, with a return line that goes directly back to the tank.
    I have read on this forum that some guys were thinking of doing it: https://forums.lr4x4.com/topic/71746...p-alternative/
    Thinking of using this pump https://www.injectorsonline.com/fuel...bosch-910.html which has the correct pressure at 5bar, however the flow rate is 130lph instead of the current LR pump of 180lph. According to the chaps on lr4x4, this isn't a problem.
    Reasons for doing this;
    1) Increased reliability
    2) Don't have to drop the tank in the middle of nowhere to replace
    3) Pump is cheaper, a lot cheaper
    4) Will be looking at doing a veg oil conversion in the future and the current Td5 pump WILL NOT be able to cope with veg oil. So this is future proofing that. But lets not focus on this for now haha.
    5) Bosch pumps can be found worldwide.
    So my questions are:
    1) Has anyone done this, or know of anyone that has done this?
    2) Can you recommend an external in-line pump that I can use that will supply the correct pressure and flow rate. Will the v8 pump work?
    3) Are there any major concerns with this system? With potential solutions?
    Thanks all.
    Land Rover
    Defender 110
    TD5
    @saffaoverland
    Thanked: 1267
    Default Re: Td5 external fuel pump alternative
    One can buy the vdo pump only, and then fit into the existing housing. The pump costs in the region of R2500, so it's much easier and more cost effective to replace than do what you're planning to do.
    PM me for the VDO part number if you're interested.
    Edit: See here : https://www.4x4community.co.za/forum...mp-Part-Number
  3. The Following User Says Thank You to NewLandy For This Useful Post:
    Jun 2016
    Randfontein
    Thanked: 2290
    And on both the disco and defender td5 you dont have to drop the tank to get to the pump. Uou can access it from above.
    Willie
    2020 Nissan NP300 2.5TDi S/C
    Jan 2017
    Rustenburg
    Thanked: 975
    Yep. I have previously done exactly what NewLandy says, and swopped over a new VDO pump onto the existing housing.
    at R2500.00 it really isnít worth re-inventing the wheel.
    i would also suggest cutting a hole in the floor pan and fitting a cover, so you can access the pump without dropping the tank out. The Doscoveries have this as standard, not sure why they didnít do it with Defender.
    my opinion regarding the flow rate, is that there is a pretty big difference in volume between 130lph and 180lph. That extra volume is going to make a big difference to the fuel temps, especially in High ambient temperatures, in low range.
    Jan 2017
    Rustenburg
    Thanked: 975
    In the defender you need to cut a whole in the floor pan to do this. It doesnít come with a hatch like the Discoveries do. But it is a very worthwhile mod to do.
    Jun 2016
    Randfontein
    Thanked: 2290
    Quote Originally Posted by RPiet View Post
    Sorry then I was mistaken, my FIL's defender did have this mod then.
    Willie
    Mar 2015
    New Germany
    Thanked: 503
    Other way you can do it is use a surge tank where you have one or two pumps which can be run sepretly so one is a spare and switched over with a switch
    you use a LP pump to pump fuel into surge tank and then that pumps HP to injectors through a filter as well and then back to main tank
    2005 Defender TD5
    Sep 2019
    Okay I'll cut a hole in the floor and make a hatch so I can access it easier.
    Any idea on where I can get a VDO pump from?
    https://www.spectromatic.net/product...y-2-5-td5.html
    I found this one from Bulgaria, works out to be R1250ish excluding customs.
    How easy is it to dismantle the fuel pump assembly to insert the VDO fuel pump?
    Land Rover
    Defender 110
    TD5
    @saffaoverland
    North of Rooiberg.
    About a year ago i bought a BOSCH pump from Naskar spares in pretoria for R800. Most of these pumps seems to be the same dimentions. The one i bought was for VW or Audi and delivered 4 or 4.5 bar. I used it in my D2 td5 and its still working 100%
    Werner Smit
    2001 Defender 130 TD5
    2005 Discovery 3 TDV6
    2003 Discovery 2 TD5
    1999 Discovery 1 300tdi with lots of mods
    19 something Forward Control 2B
    Oct 2015
    Thanked: 103
    I dropped the tank the other day and it was a ###### job.
    https://youtu.be/qyat8WY2DRY
    Cleaned the tank and pump and put it together again.
    Today I finished the inspection hole. I dont want to drop that tank again.
    I would like the part number for the VDO or the Bosch pump please.
ID:	545417   Click image for larger version.
ID:	545418   Click image for larger version.
ID:	545419   Click image for larger version.
ID:	545420   Click image for larger version.
ID:	545421   Click image for larger version.
ID:	545422   Click image for larger version.
    ONE LIFE!
    Thanked: 939
    Tsotsi on the forum here works for VDO in Jo-burg. I got a pump that I built back into the original plastic housing on my Disco 2 Td5. I had a thread running at the time with the correct part number that I will try to find and add here.
    This is the link to that thread with the part number.
    https://www.4x4community.co.za/forum...d.php?t=294115
    The humble person makes room for progress; the arrogant person believes theyíre already there.
    2004 Disco 2 Td5
    Suzuki SJ410 (being rebuild)
    VW Touran 2.0Tdi
    Lotus 7 (replica - not a kit)
  13. The Following User Says Thank You to Paul#25 For This Useful Post:
  14. #12
    Thanked: 14187
    nicely done, neat job
  15. The Following User Says Thank You to jelo For This Useful Post:
  16. #13
    Mar 2015
    New Germany
    Thanked: 503
    do you have the measurements to the center on the cap or pump soone can do this
    thanks
    2005 Defender TD5
  17. #14
    Oct 2015
    Thanked: 103
    I searched the web and got this measurement for a 110.
    I first drilled a pilot hole to look through but it was off. After 3 more I got it centered.
    I will say the more correct measure is
    520mm from the very back of the door opening and 520.5mm from the right mudguard
    Dont let the drill sink too deep because the tank sits close to the crossmembers
    ONE LIFE!
