3.2 did engine gesoek - Page 2
Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 21 to 40 of 109
    Thanked: 203
    Default Re: 3.2 did engine gesoek
    I always thought the common rail was introduced in SA in 2010 only. The power and torque on the Gen3 and Gen4 remained the same from 1999 to 2009. 2010 versions went from 120kW to 141kW but also gained a variable vane turbo at the same time.
    As far as I know some of the developed countries got a 129kW common rail in 2007.
    Barberton
    Thanked: 1025
    Commonrail definitely with first Gen4 arrival. Power upgrade later when variable geometry turbo was introduced.
  3. The Following User Says Thank You to RoelfleRoux For This Useful Post:
  4. #23
    Thanked: 203
    Thanks RoelfleRoux.
    Assumption is the mother of all bugger ups.
  5. #24
    Centurion, Pretoria, SA
    Thanked: 331
    I learnt recently that there are some changes to the head as well. HP diesel pump for common rail also different .
    SOMETIMES I WAKE UP GRUMPY,
  6. #25
    Thanked: 10626
    yep, injectors are completely different
  7. #26
    Feb 2019
    Thanked: 22
    Here is a summary of the 2010 update to the common-rail 4m41
    https://www.wheels24.co.za/NewModels...riven-20100611
  8. #27
    Dec 2011
    Thanked: 2333
    All are direct injection
    Gen3 pajero is pump injection (mechanical injectors)
    Gen4 pajero is common rail
    All the tritons are common rail
    Be careful though. There is a gen4.1 pajero and gen4.2 pajero
    Gen4.1 pajero has
    - Injectors with less nozzles and less injections per cycle
    - single piece intake manifold without swirl flaps
    - wastegate turbo
    - atf dipstick
    - jatco auto gearbox
    Gen4.2 pajero has
    - injectors with more nozzles and more injections per cycle
    - dual piece intake manifold with swirl flaps
    - vgt turbo
    - no atf dipstick
    - aisin gearbox
  9. #28
    Langs die rivier, op n berg
    Thanked: 2493
    Strip van egine gaan nou spoedig beginClick image for larger version.
  10. #29
    Feb 2019
    Thanked: 22
    Is this the one that was recovered in Kang by SADC assist after the oil filler cap was left off? That was also a 2009 model.
  11. #30
    Thanked: 2493
    Quote Originally Posted by ChasingSunsets View Post
    Nope. An other one.
  12. #31
    Nigel
    Thanked: 2110
    No. That car was running 2 weeks later.
    LC 78 Troopie 1HD-FTE
    Uniglide
    +27 zero eight 2 four 95 9252
  13. #32
    Dec 2011
    Thanked: 2333
    Sterkte. Ek hoor net horror stories van 3.2 rebuilds.
    Maak seker jy kry die regte headgasket dikte. Daar's n paar.
    As jy injectors ruil moet jy hulle incode anders gaan kar rof loop.
    Double check tappet clearances voor jy start en weer na 1000km.
    Maak intake manifold skoon terwyl jy kans het.
  14. #33
    Thanked: 2493
    Dankie.
    Sal maar kyk wat plan is na oop is.
  15. #34
    Thanked: 2493
    As mens n did common rail engine uit n pajero auto haal, hoe maak mens die torque converter los voor mens engine uit haal?
  16. #35
    Thanked: 2493
    Agter die cover is die 6 boute
  17. #36
    Friemersheim, Southern Cape
    Thanked: 2208
  18. #37
    Thanked: 2493
    Baie dankie. Ek waardeer
    Ek het net gesukkel om te sien waar mens die torque converter boute los maak. Toe kruip ek onder in om dit te soek. Neem aan ek het die cover gekry wat moet af om toegang tot boute te kry.
    Hopenlik is engine more uit
  19. #38
    Thanked: 2493
    N aspris vraag: waar kom die horror stories vandaan, as die 3.2 fisies onmoontlik is om te breek
  20. #39
    Dec 2011
    Thanked: 2333
    Enige engine sal breek as hy laag op olie en/of coolant hardloop.
    Niks is onbreekbaar nie.
    Ek wens net meer karre sal maak soos die touareg
    As hy laag/warm word op coolant/olie dan skreeu hy op jou. Maar selfs dan moet die bestuurder stop, anders gaan daai engine ook op pak.
  21. #40
    Thanked: 2493
    Yip. Veral laag op olie
