1HZ Turbo by SAC.....???
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 44
    Bethlehem
    Thanked: 4218
    Default 1HZ Turbo by SAC.....???
    This must have been discussed ad neuseam, I know.
    I've just sold my V6 Prado I think.
    And I have this MINT 2010 76 Series 1HZ. With a SAC Turbo. Car is mint, driven and taken extremely good care of by a pedantic Owner whom I know well.
    I've taken it for a spin, and well - I'm hooked. Goes unbelievably well, no turbo lag, I can feel that whistle has been set up to just give that little extra to the 1HZ.
    EGT's are around the 500 Degrees mark, so really very "cool"........??
    So................IF I want ti keep this car for a while:
    1) What to look out for/test??
    2) Is that Madman Monitor a reliable, tell tale thing, meaning will it prevent engine hiccups if used and driven responsibly?
    3) ...........Would you??
    THANKS............I may be messing up my Ad in here discussing this Car, but no issues, All the more for being an open and transparent discussion, for either me or Prospective Buyers.
    2008 Mercedes Benz CL 500........................"Bullet"
    2006 Mercedes Benz C 180K........................"Sussie"[/COLOR]
    Potchefstroom
    Thanked: 48
    Default Re: 1HZ Turbo by SAC.....???
    Petri, beide ek en jy het nie te lank terug hier ge commnet op n post van n ou wat so ene wou koop. Waar is daai Petri en wat het jy met hom gemaak? Gaan lees net weer jou eie posts ou maat. Daar het jy wyse woorde gepraat
  3. The Following User Says Thank You to Reece For This Useful Post:
    Bethlehem
    Thanked: 4218
    Goeie antwoord Pellie.Nie wat ek wil hoor nie, moet se.............
    Maar hy jeuk KWAAI, daai 76 maak my lekker voel.
    I just want to know about the success stories here I guess - en seker ook maar die warm stories ook, ja
    Daai kar is SO nice.................
    Thanked: 12783
    How long has the turbo been on?
    Okahandja, Windhoek
    Thanked: 808
    Petri, sit n inercooler by en ry hom........ hou die EGTs dop elke keer as jy voet neersit, tot jy gatvol gekyk is vir die EGTs, verkoop hom dan
    Johan Kriel
    LCs, Hilux and Echo Chobe
  7. The Following User Says Thank You to JLK For This Useful Post:
    Bethlehem
    Thanked: 4218
    Installed at under 30000km jelo, and current miles is now 118000. Done by SAC, and they also serviced the car since the installation. SAC Centurion.
    Johan, julle Duitswesters laat alles so maklik klink....dis hoekom julle 500 km ry vir 'n Sondagbraai by 'n pel8)
    Thanked: 12783
    jy hoef nie, die Madman kan gestel word om te skree as die EGTs te hoog raak
    Thanked: 12783
    As hy nog nie gekalf het nie, dan sal hy nie.
    Sit die intercooler in.
    Bethlehem
    Thanked: 4218
    Hys gestel op 620 dink ek - maar (leeg, op ooppad) kom hy nie sommer verby 500 nie.
    Interessant genoeg, ek Google nou net met my min meganiese kennis:
    1) Daars mense op Mud wat reken die low boost turbo is eintlik SLEG, want jy over "compensate" met 'n heavy voet op die pedaal, en dit neuk die combustion chambers op
    2) Baie okes reken 'n dikker zost is goed vir laer EGT's. Klink ook mooi.
    3) Die 1HZ se pistons het een of ander "wand" (coating??) wat nie lekker met die hoe druk van 'n whistle (mag) werk nie.
    4) As jy heeltyd of vir 'n lang ruk bo 700 degrees ry gaan jou turbo en/of valves chop, en jou pistons kan crack. Eina.
    SO....................
    Weet nie.
    En weereens - dis SO 'n nice kar die, baie BAIE meer driveable.
    Ek like die N/A Diesel, die 1HZ.........maar sal nie met hom kan leef in iets soos 'n 76 nie, hy is genuine net te lui op ooppad.
    Bethlehem
    Thanked: 4218
    Jys serious jelo?? Eks stupid met die goed.
    Wat doen die intercooler, laer temps??
    En dan........kan mens kyk of die fuel nie "te hoog" gestel is nie?? Lyk my dit maak dinge warm.........?? As mens daarna kan kyk en nog so paar tests doen en alles lyk soos 'n 1HZ met 120000km op - wat kan skeefloop??
    Ek probeer myself inchat hier ja want DAMN dis lekker 76 die, maar ja, wil ook maar so informed as possible wees.
  13. #11
    Thanked: 12783
    Ja
    Too much fuel = smoke and heat, high EGT
    Actually, the small turbo will actually make the engine run cooler as it is working like an altitude compensator and makes sure there are very little unburned hydrocarbons which cause soot, carbon deposits, and increased wear on engine components.
    If it has been OK for almost 90,000kms, THEN DON'T FIDDLE WITH IT.
  14. The Following User Says Thank You to jelo For This Useful Post:
  15. #12
    Bethlehem
    Thanked: 4218
    Eintlik baie blerrie logies...........thanks
    Still - what tests are there, in this case?? Just for peace of mind??
  16. #13
    Aug 2017
    pretoria
    Middag manne, ek het in dieselfde bootjie gesit n paar maande terug en in alle geval my 76 met die SAC conversion gekoop. Hy het wel n dikker uitlaatpyp en ook n intercooler op. Teen 110km/h sit EGT gemaklik tussen 280-350. Hoogste wat hy ooit gegaan het was 470(Josini bult uit met kamp wa en gelaai vir Moz!!) Ek kan wel s as jy regtervoet te diep trap styg EGT vinnig (overfuel dalk?) so n man moet als dophou en jou bestuurstyl aanpas, hou die enjin in hor rpm veral op oop pad, eerder 4e rat bulte uit as in 5e, en alle temps bly ver onder parameters. Ek sien die Ausies sit n oil cooler ook op? My olie temp was nog nooit bo 74 nie? Wat reken julle is normale oil temp vir n groot diesel? Absolute puik wa, veral as mens eers begin regtig 4x4. En die fluitjie help beslis in die dik sand!
  17. The Following User Says Thank You to barries3.2 For This Useful Post:
  18. #14
    Thanked: 12783
    fuel/air ratio analysis
    SAC should have a unit that can check that.
  19. #15
    Jan 2017
    Rustenburg
    Thanked: 975
    Die probleem met a turbo op n 1HZ sit tussen die stuerwiel en die ruglening.....
    A turbo op 79 pick up wat duer n drywer gery is, wat geen mechanicals verstaan nie, is ### soek. Maar as jy weet hy is daar, en verstaan wat sy doel is, en jy weet om EGTs te check, veral as jy sleep of in sand ry.... Dan maak hy n groot verskil. Koop hom en geniet him.
    that said, moet nou nie 1.4 bar boost op n 1HZ sit, met stock internals nie, die is net simple. As jy daai tiepe krag soek, Koop vir jou n 1HDFTE.
    (op n ander nota, ek het vir jou PM gestuur.... wat gaan aan met die Series 3 met die Chevy in wat nie wil start nie)
  20. #16
    Thanked: 71
    As daardie pre - turbo temps is klink dit heel goed ...
    UZJ 42 LX: Olive (Sold)
    HDJ 75 RV Troopy
  21. #17
    Swakop
    Thanked: 607
    we running one with the safari turbo conversion on. Has 200k km on. big tmic. Madman. Zaurst. No issues so far (touch wood). That said it doesnt get driven over 110km/h, never tows and is serviced regularly etc.
  22. #18
    Thanked: 137
    If you want a 76 turbo diesel, get the V8. Putting a race jockey on a donkey doesn't end well
  23. The Following 4 Users Say Thank You to Greenhorn For This Useful Post:
  24. #19
    Kathu
    Thanked: 2736
    Dit is die pad wat Petri gaan loop
  25. #20
    Bethlehem
    Thanked: 291
    Petri jy kan nie ń plaasperd se gat terpentyn smeer en dink jy wen die July , hy vrek lank voor die einde .
    Cruiser 76 EFI 4.5 FullTime 4x4
    Cruiser 78 4.2 Diesel
    Cruiser 79 4.2 Diesel Full Time 4x4
  26. The Following 2 Users Say Thank You to Swart Jan For This Useful Post:
