Discovery 4 Out of ideas... - Page 2
Results 21 to 33 of 33
Thread: Out of ideas...
    Tzaneen
    Thanked: 261
    Default Re: Out of ideas...
    Simple question,is the aircleaner element new?
    2012 RR TDV8 4.4
    2006 TDV6 SE A/T(Sold)
    2008 FL2 TD4 SE A/T
    1968 Renault 8 Gordini
    Thanked: 183
    Might sound stupid, but perhaps swop out the sensors woth your friends Disco? Process of elimination.
    And have the cats(dpf's) removed and install mini cats, if needed.
    Si vis pacem, para bellum
    Sep 2018
    Pietermaritzburg
    Default Re: Out of ideas...Resolved.
    4 different workshops, 2 primary turbos , set of injectors , cross over valve , boost pipes , vacuum hoses , body off 4 times , intercooler , ECU software change x 3 , intake manifolds and countless man hours spent...….the problem is 1 gasket worth a few bucks.What I now know is that the previous owner had both turbos removed and reconditioned after a primary turbo failure. In this process the secondary turbo was reconditioned but never assembled correctly to turbo shut off valve. The technician failed to insert a gasket between the shut off valve and the turbo. Without this gasket exhaust flow is not fully directed to the primary turbo under 2500RPM and instead bleeds off into exhaust system. So the lack of sufficient exhaust pressure/flow being directed to primary turbo prevented turbo from spooling up to potential, hence lack of power under 2500RPM. New gasket now fitted and vehicle drives like a dream. Live and learn. Thanks for the input guys.
ID:	554478   Click image for larger version.
ID:	554479   Click image for larger version.
    Discovery3 TDV6 Freelander II Discovery II Defender 110
    Cape Town Southern Suburbs
    Thanked: 1123
    Quote Originally Posted by AntonRabe View Post
    Damn, how much did that troubleshooting exercise cost approx?
  5. #25
    May 2013
    Thanked: 25
    Thumbs up Re: Out of ideas...
    Well done Anton
    2007 Discovery 3 V8 SE
    2015 Hyundai IX 35 Limited Edition
  6. #26
    Tzaneen
    Thanked: 261
    Glad you got it sortedSuch things can really drive one mad!!
    2012 RR TDV8 4.4
    2008 FL2 TD4 SE A/T
  7. #27
    Oct 2015
    Thanked: 93
    Well done! I would have given up mainly because im not mechanically inclined or have time or patience..but i can see you had all 3!
    Discovery Landrover 3 tdv6 2008
    Volvo S40 T5 2006
  8. #28
    Jul 2018
    Thanked: 74
    thanks for the feedback. thats crazy
  9. #29
    Thanked: 494
    Hats of to you and your perseverance, and sharing it with us, you may just have saved someone else from going through this in future.
  10. #30
    Tzaneen
    Thanked: 261
    These things happen!BIL had his LC70 gearbox overhauled in Bots @R25000.They forgot to fit a seal resulting that when reaching RSA(Paarl) box was fubar again!!Some more R25000...sorry!
    2012 RR TDV8 4.4
    2008 FL2 TD4 SE A/T
  11. #31
    Sep 2018
    Pietermaritzburg
    I haven't kept record of all expenditures and approached the concern a little with my head in the sand, not really wanting to know what the rand value end result was. Also, the previous owner's expenditure is included in my summary. I'm told he spent about 75K before giving up. Myself, perhaps about...… let's leave it as enough.
  12. #32
    Oct 2015
    Thanked: 93
    Well this one is now tied to the hip...until death do us part!
    Volvo S40 T5 2006
  13. #33
    Oct 2007
    Uitenhage
    Thanked: 517
    On the bright side. At least your vehicle has had a thorough inspection with some new bits.
    2004 Land Rover Discovery 2 Td5 ES
