Defender Td5 Comparisons
Results 1 to 18 of 18
Thread: Td5 Comparisons
    Sep 2018
    Default Td5 Comparisons
    Hi All
    I am curious about a few items on my son's 2004 td5 defender. I own a Puma so obviously I cant compare.
    Average fuel consumption is 8.5 km/litre.
    Currently keeping maximum speed to about 110 kms/hour as advised.
    Is this the recommended speed on the open road so as to look after the motor.
    When going up hills he needs to keep the revs up or drop down to fourth gear.
    Again what would the recommended rpm/s be and what could he push it to so as to maintain speed in fifth gear. Thanks.
    Sep 2011
    Thanked: 130
    Default Re: Td5 Comparisons
    With the 110 td5 there is no rev counter so my driving is not done via reference to revs but rather via power feel and engine sound.
    Cruising on the highway I keep it to between 90 and 100 trying to keep it at around 95. This feels to me to be the comfortable car happy speed with the idea of maximising the life of the car. Saved a fair wack in speeding fines a well.
    Not flooring it in 5th and just dropping to 4th on hills when the speed drops to about 80 and then being patient and keeping it steady at 80 to the top is the way to go. Few hills cause a drop to 60-70 requiring a drop to 3rd gear. Thats pretty much it - reckon the best is kep it simple and safe and don't push your luck. Lets face it - it is a glorified tractor.
    Sep 2018
    Quote Originally Posted by Roadman View Post
    Thanks. Doing 80 in fourth gear on the hills is pretty much where we are as well.
    Mar 2013
    Thanked: 401
    My td5 will happily run 120km/h all day without any worries. Revs sit at 3000rpm which is where the torque and power curve combine nicely.
    Removing the centre silencer and installing a larger intercooler did my landy wonders. The td5 isnt bothered by revs. When cruising at 110 I easily achieve 9km/l
    Pieter Greyling
    ONE LIFE, LIVE IT!
    ORRA: Z85
    LROC member:5881
    -Land Rover Defender 110 Td5
    -BMW F800GS
  5. The Following User Says Thank You to pjf110 For This Useful Post:
    DJR
    Thanked: 13547
    doesn't sound right
    An unladen 110 TD5 should maintain 100 in 4th with no issues, just not for extended periods. 3000rpm should be nicely in the middle of the power band.
    That being said: MONITOR EGTS.
    livingstone
    Thanked: 163
    Lets face it - it is a glorified tractor.[/QUOTE]
    So true and so honest!!!!!
    Sep 2018
    Thanks. This Td5 has a rev counter. What would the recommended rpm be over long periods of driving.
    doesn't sound right
    May 2007
    Mauritius
    Thanked: 239
    Most TD5 do have rev counters. At 90km/h I'm running at about 2500-2600rpm which is good enough for me to control the vehicle on the road
    Sep 2018
    Thanks all. Apologies if I am asking dumb questions. One other thing I have noticed when driving behind him is a large puff of black smoke on each gear change. What would the various options be as to the cause of this.
    Thanked: 13547
    Quote Originally Posted by Antrover View Post
    under 3000RPM but rather get an EGT probe and gauge and KNOW what the exhaust gas is doing, because EGT is the only true indicator of fuelling and load
    Sep 2018
    Thanks. I will do this. Is there any particular guage that you would recommend.
    Jan 2017
    Rustenburg
    Thanked: 975
    madman is by far the best choice. https://www.madmandevelopments.com/
    all my diesels have one fitted, before I take them on anywhere
    Thanked: 1112
    Defenders have the aerodynamics of a block of flats and road holding like a drunken hippo. I've found that doing 100-105km/h is where they are comfortable at - and at that speed my knuckles also don't go white nor my eyes wide. There is still some oomph left to accelerate when passing and my fuel consumption sits at about 9,3km/l.
    1959 SII 88"
    197? RRC
    2002 Defender Td5 D/C
  15. #14
    Oct 2015
    Thanked: 94
    I have the 2004 Defender 110 Hardtop. I also feel that comfortable cruising is at round 90km/h when the revs are at 2500rpm. When at 100km/h I should say about 2750rpm and at 110kmh at 3000rpm.
    I gear back to fourth when the revs start so go under 1800rpm. That is when the turbo boost is dropping.
    Black smoke on gear change is when turbo is not spooled up or clean/check MAF sensor.
    I removed mid silencer to get the turbo to spool up easier/earlier.
    Fuel consumption: 10km/l is what I try to get.
    9 km/l is what I get
    8km/l when towing or headwind or at 110km/h
    7km/l 4x4 thick sand overlanding and towing
    ONE LIFE!
  16. #15
    Sep 2018
    Thanks for all the info. I will take it in for a check regarding black smoke next week. Reading up on this it looks like it could be dirty air filter, timing, damaged pipe to turbo, faulty sensor or last resort faulty injectors. Is there anything else that I can have checked?
  17. #16
    Aug 2014
    Yzerfontein
    Thanked: 184
    Quote Originally Posted by tripodontour View Post
    So true and so honest!!!!![/QUOTE]
    If I'm not mistaken...in the UK it is classed as a truck..?
    2006 Defender 90 CSW Td 5
    Nissan Patrol 3 lt V-6 d/c - sold
    Nothing is ever what it seems.....:
    The ''Bitterness of Poor Quality remains long after the Sweetness of Low Price.....''
  18. #17
    Aug 2017
    Thanked: 46
    My Td5 130 cruises at 110-120km/h comfortably at around 2800-3000rpm. I try not to take it over 3000rpm for more than a few seconds as the motor feels strained. Big hills can drop the speed down so downgearing to 4th and just sitting at 2900/3000ish until over the hill is the best option. As everyone has advised, get an EGT monitor for the Td5. It can save your motor!
    Defender V8 1994
    Defender TD5 2001
  19. #18
    Sep 2018
    Thank you all for the advice
