Chassis to Tub Dimensions
Results 1 to 5 of 5
    Thanked: 449
    Default Chassis to Tub Dimensions
    Hi
    Anyone with an 88'' series 1
    I have installed a new rear cross member (bumper)
    Want to weld on the 5 small brackets with the 2 mounting holes.
    So welding to bumper and bolting to TUB.
    Similar to below but welded to bumper.
    So from the top of your bumper to the centre of the bolt hole.
    I cant find this. I have the tub on for measuring position but not correct heights.
    (pic is not my S1) Mine has 5 flat plates to be welded on.
    Any help please and Thanks
Name:	rear cross.png
    Defender Kalahari
    Series 3 SWB
    Series 2 SWB (Near Future)
    Series 1 Station Wagon 88''
    Thanked: 1578
    Default Re: Chassis to Tub Dimensions
    Mr Gary Frank, please pick up the white courtesy phone....
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Thanked: 560
    You're quite a couple of hours to early, John...
    ENJOY!!!
    Ettienne
    196? S2B FC "Over Lander" Camper
    1980 Range Rover
    2002 Defender Td5 D/C
    2004 Disco Td5
    Thanked: 395
    Ja....my so called ďfriendsĒ
    Iíve posted RCM drawings on the forum somewhere but thatís S2 & 3
    Will try remember to measure a 107 and 80 when Iím at the shop later.
    Thanked: 395
    Iím getting 25mm from to top of the RCM to the hole centerClick image for larger version.
