Defender Fuel rail pressure sensor
Results 1 to 2 of 2
    Brakpan
    Default Fuel rail pressure sensor
    Hey guys
    I have a 2013 110 land rover defender 2.2 thats been going into limp mode and getting a circuit intermittent error on the fuel pressure sensor.
    Is this a common problem on the 2.2 motors?
    Not sure what else could cause the error codes?
    Otherwise everything runs fine ect.
    Thanks in advance Name:  Screenshot_20191009_092135_com.android.gallery3d.jpg
    Jan 2010
    Fourways Gardens
    Thanked: 587
    Default Re: Fuel rail pressure sensor
    Dp it sounds the like the sensor is faulty doesnt it? Maybe look at replacing it first and take it from there.
    Defender Puma Raw Limited Edition
    Series III 88"
    Scout Nomad
    Chop your own firewood and it will warm you twice
