Fortuner 2018 Fortuner 2.4 GD6 light bulb type
Results 1 to 9 of 9
    Sep 2013
    Thanked: 16
    Default 2018 Fortuner 2.4 GD6 light bulb type
    Does anyone know the type of bulbs the 2.4 take. It has the halogen headlights where the low beams and high beams are separate. I cant find this info anywhere so far.
    I would like to get replacement LED type lights.
    Any help will be appreciated.
    Sep 2018
    Thanked: 12
    Default Re: 2018 Fortuner 2.4 GD6 light bulb type
    55w HIR2 Bulb on the low beam.
    You can modify an HB4 led to fit
  3. The Following User Says Thank You to nicktuna For This Useful Post:
    Sep 2013
    Thanked: 16
    Quote Originally Posted by nicktuna View Post
    What does the modification entail ?
    Jan 2019
    Otjiwarongo
    Thanked: 64
    HIR2 bulb and a HB3U bulb
  6. The Following User Says Thank You to JWR For This Useful Post:
    Sep 2013
    Thanked: 16
    Quote Originally Posted by JWR View Post
    I presume the HB3U is the high beams ?
    Sep 2013
    Thanked: 16
    Quote Originally Posted by Ivtec View Post
    I quick had a look and it's the HB3U confirmed. Just need to find out what the fog lights are now.
    Jan 2019
    Otjiwarongo
    Thanked: 64
    Foglight takes H16 bulb
  10. The Following User Says Thank You to JWR For This Useful Post:
  11. #8
    Sep 2018
    Thanked: 12
    Just some light trimming of the locating tabs with a dremmel.
  12. The Following User Says Thank You to nicktuna For This Useful Post:
  13. #9
    Jun 2007
    Thanked: 53
    Or just get the correct bulb - www.the-led-shop.co.za
  14. The Following User Says Thank You to AndyF For This Useful Post:
