homemade bending dies.
Results 1 to 18 of 18
    durban
    Thanked: 1120
    Default homemade bending dies.
    I tried making a homemade shower out of stainless by welding it up. It is time consuming as I weld badly. I am trying to make a tube bender but dont know the ins and outs and theory of tube bending.
    I have machined a die and a smaller one and it bends steel pipe. On the stainless its harder and not happy with the results.Does anyone do this on a regular basis who can give me some tips.?
Name:	19mm die complete.jpg
    Dec 2014
    Thanked: 1918
    Default Re: homemade bending dies.
    The characteristics of the pipe may not lend themselves to clean bends and may kink or ripple on the inside radius.
    Try filling the pipe with fine sand and plugging the ends before bending again.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    durban
    Thanked: 1120
    In steel pipe I am getting a clean bend with minimal distortion. I think without using a mandrel bend there will always be minimal wrinkage. I am getting a good bend in steel but stainless I havent tried. Stainless is expensive so I am trying to master my technique first.
    Trying to make a mandrel becomes expensive.I dont think sand will make any difference in my bends.It will be to awkward to pack it tight enough and cap it .I could try making a mandrel for it but true mandrel benders are very expensive.
  4. The Following 2 Users Say Thank You to plunger For This Useful Post:
    Hillcrest, Malaysia
    Thanked: 6517
    You live in Durban. Take a walk around one of the many many boat shops and builders and marine suppliers.
    I had a friend who had a business making formed S/S work for the boating guys. He certainly managed some beautiful look bands and forms in S/S. And that S/S they use on boats is special stuff.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
    King Williams Town
    Thanked: 1117
    Try heating up the pipe to cherry red and then bend
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
    Thanked: 262
    with salty sand inside
    Robbie
    Fortuner D4D
    Hilux 2.7 4x4 Raider.
    durban
    Thanked: 1120
    It bends plain old steel quite nicely with little deformation.
    Thanked: 732
    For tighter bends and thinner wall thickness, you're going to need a mandrel. Looking at your machining work, you'll make this easily. I have a very simple mandrel tube bender that does 25 mm stainless on a 100mm radius. I have not tried it with a smaller radius. The main difference with a mandrel bender and what you have is that you clamp the pipe to the main die and rotate the die, pulling the tube with you.
    But if you only need this for single shower rail, it's best just to shop this out?
  10. The Following User Says Thank You to Heinz Modricky For This Useful Post:
    Jan 2015
    Vredenburg
    Thanked: 943
    You can also fill the pipe with water and then freeze it (if it's not too long for your freezer). The method is used in bending coper pipes into tight coils by Engineer775 on YouTube.
    Apr 2018
    Umhlanga
    Thanked: 659
    Excuse my ignorance.
    Would it be possible to place an electrician's bending spring inside the 15mm ss pipe to act as a mandrel?
    My experience with stainless pipe, is that it is very thin walled and brittle. Do you heat the pipe first before doing the bend?
    If it is a one off shower stand pipe or similar, why don't you fabricate it in Class 2 copper and chrome plate it afterwards?
    I met some crazy people.... They made me their leader.
    2014 Mazda BT-50 - Recently bought. March 2018
    2013 Nissan NP300 - Daily workhorse
    1993 Ford Courier 2.2... Odometer stopped working just over 530'000 km's. Sold 2013
    69' Series 2 Landi - Old, slow, thirsty. Go anywhere. Stolen in 2010
  13. #11
    durban
    Thanked: 1120
    Quote Originally Posted by AlexP View Post
    I have made dies for 22mm pipe but class 2 copper is very expensive. It is very time consuming to polish it and take to the south of Durban only to have to go back a week later to fetch it.
    Cobra seem to have a problem making these long enough to fit on a bath. They make one for an exposed shower but its too short at 1,5m .They are also very expensive.
    I have had calls for this but now that I hopefully can make it I probably wont get any more requests.
    As for a spring I dont think you will get it back.
    I could try make a mandrel for this but my die has a large radius and there is no crinkling at all in steel pipe, maybe stainless will but I will try doing one in stainless today.
  14. The Following User Says Thank You to plunger For This Useful Post:
  15. #12
    durban
    Thanked: 1120
    I have tried it in stainless and its not bad. It does scratch easy though. The bending die leaves a slight mark on the inside of the pipe. If you look at the die you can see the rectangular block is bolted to the round die and I havent lined it up one hundred percent.
    I made a polishing machine from a 1,5kw single phase motor and used some bearings from a pair of swing gates I scored off a job. I polish little items and space is scarce in my workshop so I put it in my radial arm saw base.
    The problem is the polishing wheels are too close to the body to get the pipe polished without scratching the pipe. I am actually scared of this machine I made and must make another one with longer arms so I dont scratch the shower pipe.
  16. #13
    durban
    Thanked: 1120
    This is the polisher I am talking about.Click image for larger version.
  17. The Following User Says Thank You to plunger For This Useful Post:
  18. #14
    Thanked: 732
    Seems like you've won. Well done.
    Just a note on filling with water and then freezing, as far as I know the water has a fairly high soap concentration to make the ice more "flexible". The better thing about ice rather than sand is that the ice expands and pre-pressurizes the tube, so you don't get any collapsing. Brass musical instruments are made the same way.
  19. The Following User Says Thank You to Heinz Modricky For This Useful Post:
  20. #15
    Thanked: 732
    The great point about an internal spring is that when you pull on it, the diameter shrinks and it loosens. You can also rotate the end of the spring and wind it up, which also decreases the diameter. You should be able to release this.
  21. The Following User Says Thank You to Heinz Modricky For This Useful Post:
  22. #16
    Apr 2017
    Durban North
    Thanked: 2076
    It is better to bend brass and either Chrome it or antique it
  23. #17
    durban
    Thanked: 1120
    Hi Dudley .I agree the old look is nice. The beauty is this die will handle brass od19,05mm or for those imperialists 3/4 inch
    I have made one now for 22mm and 19mm .
  24. #18
    Mar 2012
    Thanked: 1207
    Nice one plunger!!!
    Honda Civic Type R
    - Daily Drive
    Isuzu KB 250 Xrider - Swambo
