Crank pulley
Results 1 to 3 of 3
Thread: Crank pulley
    Feb 2017
    Pietermaritzburg
    Default Crank pulley
    Hi all
    My 2011 Santa Fe has had a bit of a noise at low RPM when in traffic. It is almost like something is loose.
    At higher constant speeds you would not hear it at all.
    I have asked advise from the dealership and was advised that it may be the crank pulley, i.e. where the rubber between the pulley is parting.
    Have any other Santa Fe owner had this issue before. I was told that a new pulley is very expensive.
    Appreciate your advice as always.
    Kavesh
    Sep 2019
    Kilcar
    Thanked: 36
    Default Re: Crank pulley
    Why not video record this, upload to youtube and post the link here. Will make potential diagnosis a little easier..
    joburg
    Thanked: 469
    Common issue on the diesel Kia Sportage, the vibration dampener comes apart, if it is the problem you can expect to loose drive via the belt at some stage.
