Grand Cherokee WJ 2004 - P0702 Error code
Results 1 to 20 of 22
    Nov 2018
    ANTANANARIVO
    Default WJ 2004 - P0702 Error code
    Hi all,
    I have again the P0702 error code, the vehicle is in limp mode. After using the diag tools, I have following faults:
    N3 input rpm sensor
    ID51 transmission slipping
    Does someone know how to repair this? I need your help as here in Madagascar, we do not have any jeep specialist. I have to import the parts if needed.
    Thanks in advance,
    Stefan
    Polokwane
    Default Re: WJ 2004 - P0702 Error code
    Check the connections to the transmission sensors - 545rfe has two on the R/H side of the 'Box (input- and output speed sensors) and one on the left - (pressure sensor) Replace all 3 if necessary - they are relatively cheap. (Available from Interspares - https://interspares.co.za/ )
    Nov 2018
    ANTANANARIVO
    Thanks DC Polokwane for your quick reply, I will check first and then see if they need to be replaced, but I had a look on the interspares website and could not find which one I should order. If you can assist please.
    Regards,
    Stefan
    Polokwane
    Double check but I believe its these.
ID:	542791   Click image for larger version.
    Polokwane
    Nov 2018
    ANTANANARIVO
    Hi DC Polokwane,
    I am sorry to revert back to you as the transmission on Grand Cherokee 2004 is not the same as on the picture you send, the places and the type of the sensor are quite different, I try to find any other how-to videos on youtube but no luck until now.
    Wilderness
    Which model do you have? Is it the 2.7 with the Merc box?
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
    Nov 2018
    ANTANANARIVO
    Hi Pieterk,
    Yes, this one, 2.7 CRD
    Polokwane
    Quote Originally Posted by Stefan-MDG View Post
    Hi DC Polokwane,
    Hi Pieterk,
    My mistake for assuming its the 545rfe
    Nov 2018
    ANTANANARIVO
    no worry!
    Is anyone else able to help on this please?
    no worry!
    Try Sakkie
    He's forgotten more about those boxes than many have yet to learn.
    https://www.4x4community.co.za/forum.../50712-Sakkie7
    Wilderness
    Was the battery drained recently? The vehicle jump started, or the vehicle towed?
    Does the vehicle have a issue to start?
    Nov 2018
    ANTANANARIVO
    No starting issue, the battery was replaced a few months ago.
    Nov 2018
    ANTANANARIVO
    Try Sakkie
    ok thanks, I will drop him a message
    Wilderness
    How many Km's on the clock and when last was the gearbox oil changed?
    Disconnect the battery terminals for 10 minutes and check if the whole lot reset.
    Those fault codes could be very old.
    Check the plug/ electrical cables at the gearbox entry for oil leaks.
    Open the top of the selector/ gearshift and clean.
    Cam position sensor could be loose, wire off or bad connection.
    I have the whole manual available if you wish.
    Nov 2018
    ANTANANARIVO
    Hi Pieterk,
    165.000 km but I think it is more as it is a second hand from Korea, the gearbox oil was changed last year in September.
    It would be very helpful if you can send me the whole manual at stefan.andri[email protected], I will check the cables but it is better if I can follow the manual.
    Thanks in advance
    Nov 2018
    ANTANANARIVO
    and what about the diagnostic errors :
    N3 input rpm sensor
    Oct 2019
    Leicestershire
    Hi there,
    For all gearbox related stuff I use this website:
    https://jeepswj.com/
    He specialises in the 2.7 and its foibles!
    I had a p0702 that I couldn't trace that turned out to be 2 failed wheel speed sensors confusing everything. I highly recommend downloading his professional software, it was about 18 so cheap as chips. You can correctly diagnose and if you have any difficulty the guy that runs the site is super helpful
    Let me know how you get on.
    Simon
    Nov 2018
    ANTANANARIVO
    Quote Originally Posted by skinthespin View Post
    Hi there,
    Simon
    Hi Simon,
    I will have a look and let you know, thanks for your kind assistance,
    Nov 2018
    ANTANANARIVO
    Hi there,
    Simon
    Hi Simon,
    I got the WJdiag with the BT ELM32, it shows P2203 ID 13 Transmission speed sensor 3 Defective circuit / Open circuit / Short circuit
    Any idea of what should be checked or replaced?
    Thanks,
    Stefan
