Axpert wifi box
Results 1 to 7 of 7
Thread: Axpert wifi box
    Thanked: 82
    Default Axpert wifi box
    I need to monitor my system while I am away. Last year I had a problem where I went to KNP for 5 days, and on day 2 lightning caused my earth leakage to trip. So after a few hours my alarm battery was flat, no cctv coverage, after a day the gate wouldnt open, freezers started defrosting. Now I have the axpert inverter on 1 bank of 105ah batteries. This will not last very long if the mains should trip. Is there a solution like a wifi plug in that will notify me when there is a loss of mains power? Usually my MIL is at home when we are gone so she can tell me what is going on. But this December she wont be there.
    17 Ranger Supercab Tdci
    12 Conqueror courage
    97 Defender HCPU Tdi (Sold)
    99 Discovery 2 TD5 GS (Sold)
    Oct 2012
    jhb
    Thanked: 6
    Default Re: Axpert wifi box
    In adding if I may, ive heard about a auto resetting earth leakage that could also help out? Anyone have any idea or similar?
    Got the same axpert etc.. Same issues. Work and home.
    I've resorted to running cameras and router directly off axpert bypassing earth leakage. One camera shows if power is on. TIA... Not ideal. But works.
    Thanked: 396
  4. The Following User Says Thank You to faniedup For This Useful Post:
    Thanked: 82
    Where do you install the software? And how does it connect to your phone app? Do you need a pc or laptop connected to the inverter at all times?
    Thanked: 396
    I used a raspberry pi with small touch screen coupled to wifi, the software stream to your phone in real time.
    The Windy City
    Thanked: 3008
    Install on a Raspberry PI, and with dynamic dns you should be able to configure it to view it from anywhere on your phone.
    Thanked: 303
    Great replies but my solution would cost only R120 to know if the power is on or not provided you can have wifi at home and internet to check on your APP if the power is on. It will not notify you but you can at least check if power is on at home.
