Series I Rover 3.5 V8 firing order and distributor wiring
Results 1 to 6 of 6
    Dec 2014
    Default Rover 3.5 V8 firing order and distributor wiring
    Hi All,
    I am battling to get my 3.5 v8 to run properly. It's idling pretty rough and it is backfiring/popping through the intake and exhaust.
    Could anyone please help me with the firing order and correct wiring of the distributor for this motor?
    Thanks in advance.
    Brad
    Nov 2011
    Langebaanweg
    Thanked: 768
    Default Re: Rover 3.5 V8 firing order and distributor wiring
    Sorry for the crappy picture.
    Watching F1.
    84' Land Rover Defender 110 V8 4-speed Hardtop (Meisiekind) Sold after 12 years of fun and hard work
    Dec 2014
    Thanked: 1576
    Thee engines are sensitive to tracking, so try to get the routing of the leads as per the diagram to avoid issues if the leads are not 100% good. You can do a quick check by starting and running the engine in a closed garage or after dark where tracking will be easily visible.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Dec 2014
    Thank you very much Guys! I will give this a try when I get back next weekend hopefully get it up and running again!
    Thank you very much!!
    Dec 2014
    Thanked: 1576
    Just to add, it could also be your distributor and/or carbs playing up and giving you rough running.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Thanked: 10119
    Or it could be the cam..........they do tend to eat cams if run on newer oils without zinc additives.
