Plastering over surfix ?
Results 1 to 11 of 11
    Aug 2010
    Durban SA
    Default Plastering over surfix ?
    I need to add a few plugs and light switches on some new walls that have gone up. I wanted to ask if the right thing to do is chase and run conduit or as it is legal do most just run surfix and plaster over it.
    For the sake of a bit of dust and a few hours chasing i think i should use conduit as i can then pull new wires if ever there is a problem but it will slow things down by a day.
    Robertson/ Larissa, Greece
    Default Re: Plastering over surfix ?
    Quote Originally Posted by warrenpfo View Post
    The first time you hit a nail through the surfix you will be sorry you did not follow your own advice!
    As long as you keep to the norm of going up or down directly above or below the switch inside the wall there should not be a problem, the moment you go sideways then a result Franscois is talking about comes into play.
    Robert
    '09 VW Caddy Maxi TDi
    '06 Citroen C3 1.4HDi8)
    '97 Isuzu 280 S/C plaasbakkie
    Johannesburg/Prague
    Yes as others mentioned plastering over power wires is a no no besides the danger after. One can reset it but then use a tube if not then the cover is low so will crack with time, do it properly a conduit is cheap
    Pajero 3.2 DID Gen 4 Standard for now
    Platcar Alfa Giulietta 1.4 MA
    Swambo Volvo S40 T5
    durban
    Quote Originally Posted by 12richardk View Post
    Its not the cost its the hassle of chasing .I cant comment but I think its perfectly legal. I think its a no brainer that conduit is a much better idea.
    Oct 2012
    Vredenburg
    Fix 2.x fibre stone discs on your grinder and rip straight up from switch or straight down from plug. Surfix is designed to run without conduit .
    plaster up and off you go. Perfectly legal aswell.
    There's only 3 reasons to stand up : to get the remote , to go to the bathroom or because you're the Real Slim Shady.
    2002 Patrol 4.5 GRX
    2001 Terrano 2 TD27
    2012 1600 Pypkar Rum mobile
    It is 100% within regulation to just plaster it in.
    The theory that it can protect against a nail through is a good theory besides the nail still going through it also dents the pipe to the extent that it is virtually impossible to get the new wire through. Had a few in my sparky career and very few ended as planned
    I fully agree with the straight lines up and down. makes good logical sense.
    Just as an aside normal twin & earth is also legal to be plastered in, loose wires unfortunately not
    Henk
    Follow us on Facebook
    Aug 2010
    Durban SA
    Thanks guys. If I do plaster it in should I still chase a bit to ensure the plaster does not crack being too thin?
    Oct 2012
    Vredenburg
    Really.fine sand plaster or just good old polyfiller.
    Use a sponge to texture.when touchdry to match texture of existing plaster.
    2002 Patrol 4.5 GRX
    2001 Terrano 2 TD27
    Jul 2013
    Op post #1.
    His new walls are not plastered yet.
    So he has to in anycase chase the walls for the plugs and light fittings .
    Oct 2006
    CAPE TOWN ,SOUTH AFRICA
    Agreed, so if you put the surfix in pvc pipe, you still can go through with a nail.
    The idea of Twin and earth and surfix was to eliminate the use of conduit in many cases.
    In about 7 complexes that was done in the Water front only once a nail went through a cable, and it was some one
    who put a nail right over the top of the switch box.
    If you work smart, it will limit the problems that can occur later.
    Just bare in mind those cables cant go in direct concrete, but in the screed yes.
    ORA
    Ian
