2016 VW Caddy 2.0TDI Maxi Trendline DSG
Results 1 to 4 of 4
    Question 2016 VW Caddy 2.0TDI Maxi Trendline DSG
    Can someone assist with the following:
    1) When ito age/milage should cambelt replacement happen on above vehicle (2016 latest facelift model - 103KW)
    2) When ito age/milage should DSG oil be serviced/replaced
    Awaiting your wisdom?
    Thanked: 653
    Default Re: 2016 VW Caddy 2.0TDI Maxi Trendline DSG
    Quote Originally Posted by Goldi View Post
    I had mine (cambelt) replaced at 100k km but the mechie suggested i do the next one at 190k km as the first one had some wear, cannot comment on the DSG as I have the MT.
    Robert
    '09 VW Caddy Maxi TDi
    '06 Citroen C3 1.4HDi
    '97 Isuzu 280 S/C plaasbakkie
    Thanked: 53
    Cambelt max every 120000km. Dsg oil every 60000km
    Current:
    2019 Tiguan Allspace 2.0TDI 4Motion DSG R-Line
    2019 Cross Up!
    2016 Metalian Maxi
    Petoorstown
    Thanked: 46
    I would again do cambelt rather on 90000kms with all tensioners. As above DSG oil every 60000kms.
    Had one vehicle still under warranty luckily that had a cambelt failure on 93000kms with full service history so next time will do every 90k rather.
    2018 VW Amarok V6 TDi
    2015 VW Touareg V8 TDi Still learning..
