Suspension 2019 bi-turbo Ford Wildtrak suspension.
Results 1 to 12 of 12
    Sep 2019
    Boksburg
    Default 2019 bi-turbo Ford Wildtrak suspension.
    I bought myself the new Ford wildtrak. I had the guys from Ironman fit a adde leave system to it, with foamcell pro shocks. After the installation I have a vibration when pulling away. What can be the problem? What can cause the vibration? It seems that it is only when pulling away.
    Aug 2017
    Thanked: 876
    Default Re: 2019 bi-turbo Ford Wildtrak suspension.
    Did the suspension changes result in a lift?
    Jun 2019
    Viljoenskroon
    Why did you do the suspension?
    Gauteng
    Thanked: 923
    I'd go straight back to the installer. Let them drive with you and then sort it. If they don't get it right, let them revert your bakkie back to standard. But that's me...
    Hope they can sort it for you. That is a nice bakkie.
  5. The Following User Says Thank You to AntonN For This Useful Post:
    Feb 2015
    Thanked: 74
    If there is a lift in the back, the increased angle of the drive shaft may be causing the vibration.
    You may need a spacer to drop the center bearing slightly.
    http://www.ironman4x4.com/products/s...bearing-spacer
    2016 Ford Everest 3.2Tdci XLT AWD A/T - Mods have begun!
    2010 BMW 320i AT (SWAMBO)
    Ex: 1998 Land Rover Defender 300Tdi - ek huil nogsteeds myself aan die slaap
    Ex: 2014 Ford Ranger 2.2 DC 4x4
    Always go for the deepest mud, muddy stories make the best memories!
  7. The Following User Says Thank You to Henko88 For This Useful Post:
    Thanked: 42
    Have them check the angle of your drive line, if the angle is to acute then it can cause vibration as well. Should be easy it fix! Keep us posted.
    2017 3.2 Ford Ranger Wildtrak D/C
    Old Man Emu lift kit
    Stofpad Box rocksliders
    Aline Dagger
    BFG KO2 285-75-16
    Stanium aluminium canopy with some goodies and stuff inside
    and loads of attitude
    Jul 2010
    Quote Originally Posted by Henko88 View Post
    I am sure this is your problem.
    Jul 2010
    Swakopmund
    Thanked: 26
    Quote Originally Posted by JBEspach View Post
    Is it a vibration or a shudder?
    DON'T BE AFRAID TO TRY NEW THINGS - AFTERALL THE TITANIC WAS BUILT BY PROFESSIONALS, THE ARK BY AMATEURS
    Jun 2008
    Pietermaritzburg
    Thanked: 24
    I also go with the centre bearing spacing causing your shudder.
    Apart from the glitch, how does the ride feel. Does it feel safe cornering or does it wallow. Do you think the cost was worth it.
    2011 I30 Huyundai platcar
    2017 Ford Ranger D/Cab 2.2 TdCi XLS 4x4 Auto
    Feb 2016
    Johannedburg
    Thanked: 35
    I would go back to standard setup. It doesn't need any after market drive terrain upgrades IMHO
  13. #11
    Feb 2015
    Thanked: 74
    Quote Originally Posted by ra_01 View Post
    The Ranger has a 127" wheelbase, and hangs over the smallest bump. I had mine for 4 years and it was my single biggest issue with the vehicle. A small lift front and back to increase the break over angle did wonders!
    Amarok has a 122" wheelbase.
    Isuzu has a 122" wheelbase.
    Hilux has a 123" wheelbase.
    The 4-5" difference makes a massive difference!
  14. #12
    May 2008
    Thanked: 11
    What suspention did you put in. I had the OME system fitted by Safari centre, and had the same problem, and OME do supply a wedge to go in under the diff to change the angle little bit, that actually comes with the kit, and that solved my problem, although I still had a slight vibration for the first month or so when I pulled away, until the hole system setteld in, I just sold my wildtrack with 100Kilos on and never had an issue again after that, and I fitted my suspention when the bakkie only had 10km on the clock.
    Pepe Kleinhans
    VW Caravelle T5 4-Motion
    KTM 520 EXC and BMW R1250 GSA
