Deep Cycle battery for trailer (Echo)
Results 1 to 12 of 12
    Thanked: 493
    Default Deep Cycle battery for trailer (Echo)
    I need to replace the OE installed battery in my Echo, any recommendations and pointers I need to take into consideration perhaps?
    (It came with a Deltec Voyage Deep Cycle 12v 70Ah)
    Thanked: 266
    Default Re: Deep Cycle battery for trailer (Echo)
    Measure for space and then decide which battery to fit.
    Thanked: 110
    Quote Originally Posted by PieterOos View Post
    Any reputable battery place can assist you. Take the old battery with and they will replace with the same dimensions. Replaced mine recently and seem to recall that the price was around R2800.
    Thanked: 493
    Thanks guys - I actually meant AGM / Gel / Dry Cell / Wet Cell, perhaps higher Ah, cycles, etc. or should I just stick to what I had for light duty application?
    Kareedouw
    Thanked: 12
    Hi Pieter, I recently installed a 100AH Rolls AGM , main advantage is more cycles at deeper discharge and faster recharge rate. They sell for +/- R3000 each.
    Thanked: 493
    Quote Originally Posted by Basterbrak View Post
    Many thanks BB, will check them out!
    (BTW, I see you are from Kareedouw, is Rensilvier still operating?)
    Kareedouw
    Thanked: 12
    No they closed doors a couple of years ago.
    Thanked: 18
    Pieter I see you are from Centurion. When I replaced my battery for my Echo a couple of years ago, I got the best deal from Echo themselves.
    Jan Lategan
    '06 Toyota Fortuner 4.0 V6 4x4
    '07 Mercedes C180
    '15 Nissan Navara 2.5 XE 2x4
    Thanked: 493
    Sad, thanks BB
    Quote Originally Posted by JanL View Post
    Thanks Jan - will contact them as well
    Jul 2018
    Paarl
    Thanked: 33
    Did the same exercise a year ago.
    Had to look around quite a bit to find a 70 ah deep cycle. Wanted to fit a 105 but they are to high to fit under the lid. Dealers from Durbanville wanted to sell me a "Deep Cycle" of 70 ah wich turned out to be just a regular 652 High Cycle. Dont know where to look in Gauteng, so good luck.
    '14 Hilux 3.0D4D DC 4x4
    '96 Hilux 2.4P DC 4x4 Bloutrein
    Echo 4 Trailer
  11. The Following User Says Thank You to Bloutrein For This Useful Post:
  12. #11
    Apr 2008
    Irene, Pretoria
    Thanked: 49
    Correct, the batteries supplied by Echo with their vans are normal high cycle batteries (Duratec)
    '15 Prado 4.0 VX
    '18 Echo Chobe
  13. #12
    Jan 2019
    Ek het tyd terug hierdie ingesit. Echo 4. Nou al verkoop. Het baie lank gesukkel om iets te kry wat pas. Soos jy kan sien het ek die “brackets “ effe verander en 4 x 60 Ah ingepas. Het geloop soos stroop.
    Enjoy Life
    Shaun Nell
