Diesel particle filter
Results 1 to 8 of 8
    Jan 2014
    Big Bay
    Default Diesel particle filter
    The DPF in our Touareg’s light came on during this week, the fuel level was a bit low and my wife only does short trips during the week.
    It has successfully regenerated after about 10minutes on the highway.
    Is it safe to use STP Diesel Particle Filter cleaner http://www.stp.eu/en/products/additi...filter-cleaner
    in VW engines? As an added measure in looking after your DPF?
    VW Amarok Highline 4Motion Auto - Mine
    VW Golf 7 2.0 TDI Highline DSG - Mine
    BMW 3 Series Motorsport 2.0 - SWAMBO
    Wartburg.
    Default Re: Diesel particle filter
    You only do short town trips during the week, most of the times?
    I would much rather just give it a good burn on the hi-way every so often to get it up to working temperatures where the PDF can burn itself clean.
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
    Wartburg.
    What is the mileage on the vehicle?
    Swakopmund
    Those VW DPFs have got that burn free cycle. The ECU measures the pressure differential over the DPF and determines when a burn free cycle becomes necessary.
    That is how the system looks after itself.
    The very first generation of DPFs were not monitored by the ECU and could clog up due to lack of longer trips. In that case it might make sense to use a product.
    In your case I wouldn't bother. The ECU looks after the DPF. At best you would pay money for a product you don't really need, at worst it might have undesirable side effects.
    2012 FJ Cruiser
    1983 FJ60 Landcruiser
    Jan 2014
    Big Bay
    Quote Originally Posted by chris8d View Post
    what is the mileage on the vehicle?
    171k
    Aug 2015
    velddrif
    my polo was on 179k when i took mine out so much better and they did the egr delete as well
    Quote Originally Posted by divanvanderwatt View Post
    171k
    Dec 2013
    Quote Originally Posted by rickyc View Post
    Did they remove the dpf or cat? Not sure the polo came with a dpf?
    Aug 2015
    velddrif
    no they never removed the cat, they just cut out the dpf and put a straight pipe in its place, if you want you can contact neville at wulfchiptegnik in cape town
