Best solar yield yet
Results 1 to 20 of 39
    Thanked: 515
    Default Best solar yield yet
    After 3 days of lower yield than during winter today was a turn around and my total yield shot up to the best level in 13 months.
    How did others find the yield today?
    livingstone
    Thanked: 163
    Default Re: Best solar yield yet
    My "dongle" monitors aren't working so I'm not sure.
    What was your yield, and what is your set up:
    Panels?
    Inverter?
    Storage capacity?
    Sep 2019
    Kathu
    This was yield this month. Inverter is SMA SB4.0 with 14 IBC Polysol 290watt RS5. Only 12 panels connected at this point. Expanding the roof to add the last 2 panels. Roof is not facing north and panels is tilted at 15 degrees. Will see what it is delivering once everything is connected. Inverter will be more efficient after the last 2 panels is added. Grid-tie system without battery backup.
  4. The Following 2 Users Say Thank You to Acidice For This Useful Post:
    Apr 2016
    Thanked: 62
    Quote Originally Posted by Acidice View Post
    So is your system powering back into the grid?
    Your total PV panel count is 14??
    Feb 2016
    Thanked: 15
    Yesterday was the best I got yet.
    Nissan Navara 2.3 4x4 LE
    BushLapa Boabab
  7. The Following User Says Thank You to isimobile For This Useful Post:
    Thanked: 515
    Quote Originally Posted by tripodontour View Post
    Panels?
    Inverter?
    Storage capacity?
    3x270W
    Solis 4G grid tied.
    No storage.
    System size to cover base load and not to export. Suddenly the daily yield went up from 3.5 to 4.4kW.
  9. The Following 2 Users Say Thank You to ekkekan For This Useful Post:
  10. #7
    Thanked: 494
    Was a good day today, got 5.7kW/kWh installed.
  11. The Following User Says Thank You to faniedup For This Useful Post:
  12. #8
    Thanked: 515
    You are getting a really fantastic yield.
    Can you perhaps share what make and Watts of panels you have installed?
    What make inverter?
  13. #9
    Sep 2019
    Kathu
    Hi Richard
    There is 14 panels but 2 of then is in the house. Would add them next weekend. So currently it is 12 panels. 2 strings of 6 panels. The inverter is set up not to export. But the prepaid meter does not trip if there is a small feed to eskom. But it does not credit for feed in.
    Montly consumption is between 1200kwh to 1500kwh. Just an atempt to reduce the electrical bill.
    Would add a battery inviter later.
  14. The Following User Says Thank You to Acidice For This Useful Post:
  15. #10
    Apr 2016
    Thanked: 62
    Hi Richard
    Your system is showing consistent power generation on a daily basis.
    Does your electricity demand always exceed the PV generated power? (i.e. that you never have excess power generated that isn't consumed??)
    What is puzzling me is if you aren't powering excess power back into the grid where is the power being consumed?
    I have the predecessor to your inverter SB4000TL-20 but have been slow to commission the system..
  16. #11
    Hillcrest, Malaysia
    Thanked: 6460
    Well spotted. Those figures tell me that all energy generated is consumed. Either by the home or fed back into the grid.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
  17. #12
    Thanked: 494
    What make inverter?
    12x265 W. AJ Panels coupled to 2x 5kVA Axpert inverters with 7.2 kVA battery bank.
    Today Even better, almost 6 kW/kWh installed
  18. The Following User Says Thank You to faniedup For This Useful Post:
  19. #13
    Hillcrest, Malaysia
    Thanked: 6460
    For the morning. You have lots of wasted energy. This can be fixed pretty cheaply.
    ZS5KAD
    3 V8's
  20. #14
    Thanked: 494
    Thanks Keith, I'm listening.
  21. The Following User Says Thank You to faniedup For This Useful Post:
  22. #15
    Apr 2014
    Thanked: 117
    Can you please explain Fluffy?
  23. The Following User Says Thank You to LdLL For This Useful Post:
  24. #16
    Apr 2016
    Thanked: 62
    The inverter has been set up as: 'The inverter is set up not to export'
    Does this mean the inverter switches off incoming excess PV power or does it power back into the grid but doesn't register it?
  25. #17
    livingstone
    Thanked: 163
    Fluffy
    I would also love to hear your solution to the "wasted" PV generated.
    My plan is to connect an A/C unit to the P/V via a contactor switch?
    Would this work?
  26. #18
    May 2010
    Gauteng
    Thanked: 15
    I had my best day this year on Monday - harvested 38,5 kWh. About 5kWh better than usual.
  27. #19
    Mokopane
    Thanked: 227
    Also noticed a definate swing.
    Die reŽn is 'n dag nader as gister.
  28. The Following User Says Thank You to retailer For This Useful Post:
  29. #20
    Hillcrest, Malaysia
    Thanked: 6460
    It should throttle generation from the PV. So when an inverter reports that xkWh was generated it implies that it was also consumed. The inverter has no way of knowing how much power could have been generated if it was restricted.
    That reported power is going somewhere. unfortunately this is where those cheap Ellies and OWL type power monitors fall short. They cant be used (easily) to debug power flow direction so what they report is the net averaged energy flow of both directions.
    Note that I use Energy and Power interchangeably, which technically is highly incorrect but much more readable for most practical purposes.
    ZS5KAD
    3 V8's
  30. The Following User Says Thank You to Fluffy For This Useful Post:
