Feroza 7AGE 20V SILVERTOP TOYOTA - Page 4
Results 61 to 74 of 74
  1. #61
    Sep 2017
    Thanked: 9
    Default Re: Feroza 7AGE 20V SILVERTOP TOYOTA
    Thank you all for the help.
    Ek is baie teleurgesteld in Goch & Cooper. Dis 'n plek wat spesialiseer in Dyno Tuning, en hulle het aanvanklik gesÍ dat hulle carburettors kan doen. Maar lyk my hulle wil net die R30 000 se fuel injection insit en wil nie die carburettors regmaak nie.
    I've got another garage that can help, but they also doesn't specialize in carbs. I'll talk to you as well Ockert. (PM you )
  2. #62
    Brits
    Thanked: 424
    Renault Duster 1.5Dci 4WD
  3. The Following User Says Thank You to JuanB For This Useful Post:
  4. #63
    Alberton / Groningen
    Thanked: 32
    Niks fout met sidies nie ... ek het vir my seun n 1800 16v gebou vir sy citi.
    Enigste ding waarop ek aangedring het was dat daar 2 side draughts op moet wees.
    Twee Dellorto DHLA 40ís gekoop en hulle gerestoreer. Alle parte vir Dellorto en Weber kan by Dellorto.co.uk gekoop word.
    My kennis was nie genoeg nie , maar het by Oom Rowland van Rowland manifolds gaan aanklop vir hulp. Elke keer wat ek in die Kaap is vir besigheid stop ek daar vir n geselsie . ( ten minste eenkeer n maand ).
    Doen jouself n guns en gaan gesels met hom ( hy is in die Kaap ).
    Beste ding wat ek kon doen was Oom Rowland en n vacuum balancer.
    Citi is Junie verkede jaar gedyno en ingestel - dis nou n jaar sonder dat ek enige verdere verstellings aan die carbs gedoen het.
    Ek is old school - so side draughts is cool !!
    2004 Discovery TD5 ES Auto
    2016 Amarok 132 kw Auto
  5. The Following 2 Users Say Thank You to ac koch For This Useful Post:
  6. #64
    Thanked: 32
    Sorry missed some info:
    Rowland carries a big range of carb kits , jets , ram tubes and filters.
    He also does the soft mount adapters - it is true that the carbs form bubbles etc.
    Give him a call - you can tell him the pain in the @ss from Jozi ( AC ) recommended him.
    He runs a workshop if you need him to do the work.
    AC
  7. The Following User Says Thank You to ac koch For This Useful Post:
  8. #65
    Sep 2017
    Thanked: 9
    Thumbs up Re: Feroza 7AGE 20V SILVERTOP TOYOTA
    Quote Originally Posted by ac koch View Post
    AC
    Thanks Ockert. He had a look at the engine and had lots of sound advice and improved the starting and running.
    Things went well, untill this morning. At the first hill, the carbs started to overfuel and flooded and plugs started to misfire.
    I got an offer by someone that came to look at is ( R42 000 ).
    I also called uncle Rowland. (Ockert pointed it out that the jepie has a Rowland intake manifold.) Rowland said that he could sort this out and that he has all the jets and emultion tubes and stuff neede. Price would be R2500 - R3500 to sort this out.
    The carbs flood when going uphill, but at one stage it shooted forward like a bullet and made the mud terrains scream for a few seconds........there is lots of power here and this jepie would be awesome in the sand when sorted.
  9. #66
    Thanked: 2393
    Float levels
  10. #67
    Thanked: 10290
    Float levels
    absolutely
  11. #68
    Strand
    Thanked: 21
    Hi Lohan, het jy hom toe na Rowland toe gevat? Vir daai koste is dit 'n winskoop. Grips, stem saam. Daarmee saam die "needle & seat" kan ook nie meer vars wees nie. Ongelukkig het ek te min kennis van plekke hierrond waar ek die regte onderdele kan kry. Maar ek sal volstaan hiermee. Sterkte Lohan, hoop jy kry hom binnekort reg. Is hy al deur die toets?
    I might be a FOOL, but I am an OLD fool - from unknown.
  12. #69
    Sep 2017
    Thanked: 9
    Jepie is at Rowlands. They replaced the rubbers between carbs and manifold with proper ones. That would privent lots of vibration on the carbs.
    And there were no bolts on the bottom of the manifold, so it could possibly suck air in there. That is now sorted.
    The carbs got a sevice kit and he said that the float levels had wrong parts in. Maybe from a Delorto carburettor, but he fitted the correct parts now. It ran well, not road tested yet, but then the distributor broke. They will replace that today and road test and let me know. I hope and believe everything will be sorted.
  13. The Following User Says Thank You to Swerkater For This Useful Post:
  14. #70
    Strand
    Thanked: 21
    Swerkater, sounds great. Did the distributor CAP broke (only held in place by 2 screws)? When will you be able to collect and test drive it?
  15. #71
    Sep 2017
    Thanked: 9
    I'm not sure. And not sure when I can collect. I would have to take half a days leave this week.
  16. #72
    Sep 2017
    Thanked: 9
    Not distributor cap, but "module" broke and were replaced. Spacers fitted between carbs and intake. New gaskets were made.
    New float levels and a few new jets. Intake manifold also had a few bolts missing. And skimming on manifold was done.
    Still the same... made no difference and it's not right at all. R10 000 down the drain and counting.
    I'm going to see if the dealer is willing to give me my money back. He basically lost a month and a lot was sorted out, and got a new battery.
    Maar ek's raad-op en moedeloos, en het nie die tyd vir die gesukkel nie.
  17. #73
    Thanked: 10290
    Skoolgelde kan lekker seermaak.
  18. #74
    Nigel
    Thanked: 2078
    Quote Originally Posted by Swerkater View Post
    Ja, dit gaan aanhou. Daardie engine moet uit en oor ingesit word. As daar so baie skete is, dan kan en net imagine hoe lyk al die ratkas en engine mountings.
    En dan soek hy 'n throttlebody.
    LC 78 Troopie 1HD-FTE
    Uniglide
    +27 zero eight 2 four 95 9252
