Nissan 1400 Specialist in Pretoria
Results 1 to 11 of 11
    Sep 2019
    Default Nissan 1400 Specialist in Pretoria
    Hi all, new guy here so please take it easy.
    I have had my 1400 bakkie for 2 and a half years now. first year no problems, last 18 months constant problems. (only 3 months after I put it on a dyno, it is cutting out, struggling to start, fuel consumption increases)
    Where can I buy quality parts for my 1400? Distributor, carburetor, fuel pump, etc. I also heard Nissan is not making any more carburetors for the 1400 specifically, any truth in this?
    If someone could please have a look and pinpoint the problems on the bakkie for me, make your price.
    Best regards
    Garden Route
    Thanked: 132
    Default Re: Nissan 1400 Specialist in Pretoria
    A mechanic that knows his stuff on a Nissan 1400 is like hen's teeth & to find one that knows his stuff and has the correct diagnostic equipment is even more rare . For parts try Goldwagen or good old Midas
    When faced with the dilemma of being right or being happy , I choose happy every time
    May 2015
    Somewhere
    Thanked: 668
    Quote Originally Posted by rodneykdc View Post
    A mechanic that knows his stuff on a Nissan 1400 is like hen's teeth & to find one that knows his stuff and has the correct diagnostic equipment is even more rare.
    Really?
    The first motor I rebuilt was a Nissan 1400, I was 16 years old. I don't imagine the 'technology' used in those engines has changed.
    When I finally got my license, I commandeered daddies bakkie. Me and my tjommies would disappear with it for days on end. Loved it, and miss it.
    A sure of intelligent life elsewhere in the universe is that none of it has bothered contacting us.
    Robertson/ Larissa, Greece
    Thanked: 4155
    Please come on! A Nissan 1400 must be the simplest of vehicles to work on! The carburettors are known to be rubbish. Fit a Golf carb if possible. If not, it is still esay to work on, there is not a lot that can go wrong. Check jets are clean, float level correct, gaskets not leaking, choke functioning and anti run on solenoid functioning. That's about it.
    Distributor check for shaft sideways play, change and set points and condenser and set timing. Maybe replace cap. And coil if really needed. Check valve clearances. That should sort you out.
    If you don't find someone to do it, contact Henris here on the Forum. He will know what to do.
  5. The Following 3 Users Say Thank You to Francois Theron For This Useful Post:
    Jan 2011
    West Rand
    Thanked: 69
    Not in Pretoria , but in roodepoort
    Oom Sakkie , 079 904 4823
  7. The Following User Says Thank You to Charlie1800 For This Useful Post:
    May 2015
    Somewhere
    Thanked: 668
    I'll never forget the day I saw a Nissan 1400 barrelling down Old Main Road in Pinetown, only it didn't have a 1400 motor in it. It had what sounded like a 305 Chevy. The air filter was sticking through the bonnet.
    Garden Route
    Thanked: 132
    Quote Originally Posted by Naes-Landy View Post
    Really?
    My tongue was deeply embedded in my cheek I doubt there is a more elementary car to work on & as for a Nissan 1400 specialist , come on
  10. The Following User Says Thank You to rodneykdc For This Useful Post:
  11. #8
    Thanked: 17104
    Carb is a standard single choke Nikki if I recall.
    See if you can get an adapter to fit a VW Citi Golf carb.
    Fuel pump: any generic electric pump will work. Midas or Autozone.
    Why did it go on a Dyno? WHAT DID YOU MODIFY?
    As mentioned, the A-series engines are probably the easiest things to work on, and are in fact a design the Japs stole from Leyland or British Motor Corporation.
    A beginner mechanic should sort that out in half a day.
  12. #9
    May 2015
    Somewhere
    Thanked: 668
    Talking Re: Nissan 1400 Specialist in Pretoria
    Are we sure it has an actual 1400 engine in it, and not a 305 Chevy conversion like the one I saw?
    So was mine
    1400 specialist? I'm sorry, the OP walked right into that one. But please don't get scared off. You will (hopefully) soon grow a thick skin and will then end up spending way too much time in here enjoying what is in fact a whole lot of wholesome good natured fun, most of the time.
  13. The Following User Says Thank You to Naes-Landy For This Useful Post:
  14. #10
    Jan 2016
    Thanked: 1547
    The sound of a 1400's doors slamming is more cringeworthy than Frau Farbissina's screams. Fun to drive on short distances though, especially with the later chunky steering wheels.
    2001 Gen 3 Pajero swb 3.2 Di-D
  15. The Following User Says Thank You to Jens78 For This Useful Post:
  16. #11
    May 2015
    Somewhere
    Thanked: 668
    Quote Originally Posted by Jens78 View Post
    Also fun for other things. Not sure why they don't use 1400's for spinning instead of the old box BM 3 series.
