Legend 50 Tailgate
Results 1 to 6 of 6
    Jun 2013
    Springs
    Default Legend 50 Tailgate
    HI Guys, just a thought, with the new Legend being keyless so to speak. How do you lock the tailgate?
    Jun 2019
    Default Re: Legend 50 Tailgate
    It comes with two sets of keys. One set for the tail gate and the other for the spare tyre.
    You can still unlock and lock manually. But the keyless entry works great.
    Quote Originally Posted by Tazz123 View Post
    Jun 2013
    Springs
    So basically, what you saying is, I should drive around with the one spare key as well? What key do you have for the spare? I have one for the lock i put on that is it, is there another?
    Jun 2019
    Apologies should have been clearer. I dont have my keys on me atm and will post pics later tonight.
    You would have been given the following:
    Two remotes
    2 keys with a black handle I usually refer to these as dummy keys and
    2 keys for the spare wheel.
    The dummy keys will open the tailgate and driver door. But also, on the back of your remote, theres a small slide-button if you slide this it will allow you to remove the top section of the remote which reveals 'another' key.
    But also be aware if the batteries are flat or there is a malfunction with the remote, you wont be able to start the legend with either the dummy or 'pop up key'; they just give you access to the vehicle.
    I personally have left the dummy keys at home and 'hid' the spare wheel key in the cab itself and just carry the remote unit.
    Hope this helps, will post pics later.
    Jun 2013
    Springs
    Thanks for the feedback
    Jun 2013
    Springs
    What would be the posibility of putting central locking on the tailgate?
