Go Big?
Results 1 to 11 of 11
Thread: Go Big?
    Wilderness
    Thanked: 1079
    Default Go Big?
    What models are named Go big?
    Why?
    What's the difference to the other models?
    What year do they end?
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
    Nov 2006
    Thanked: 179
    Default Re: Go Big?
    KB5 D tec modelle. Was 'n bemarkingsfoefie!
    Laastes was 2012. Weet nie presies wanneer het hulle begin nie. 2007?
    Bostoe
    Ballito
    Thanked: 397
    Default Re: Go Big?
    It was the 1st Isuzus sold starting around 2005 (all new model) that carried the D-Max monniker. (the 3l td then had 280 nm and 96 kw). The range following immediately on this had only upgraded looks but new powerplants - then called D-Teq. So, without calling on GOOGLE, "GO BIG" refers to, roundabout 2005 - 2012. The "GO BIG" name was derived from the ad campaign at that time.
    Mar 2012
    Pierre van Ryneveld
    Thanked: 3641
    Default Re: Go Big?
    Volgens my kennis is die 2007-2012 die KB5...
    Go big is die shape net voor hom (nie 100% seker nie maar dit is hoe ek dit verstaan) 2004'ish tot begin 2007...
    Go Big -
    Name:  Advert Pic Go Big Bakkie.jpg1700097847a7b0eaf61e9a9ad2e03fdfb7958aef9f.jpeg
    KB5 -
    Wilderness
    Thanked: 1079
    Default Re: Go Big?
    So! The "Go Big" had nothing to do with the size or shape. It was all in the marketing!
    Oct 2017
    Vereeniging
    Thanked: 32
    Default Re: Go Big?
    Coo wrecked.
  7. The Following User Says Thank You to EtienneB For This Useful Post:
    Mar 2014
    Marble Hall
    Thanked: 17
    Default Re: Go Big?
    So die D-Max engine is vervang met D-Tech engine omtrent 2007. Toe het dit " common rail " geraak. As dit so is wat het die engine verander in werksverrigting en watter voor en nadeel het dit tot gevolg gehad. Ek het 2006 model en 240 000 sorgvrye km al gedoen en wonder of ek moet op gradeer na D-Tech . Ek doen my eie meganiese herstelwerk en is skrikkerig vir die elektroniese gedeelte van n voertuig en wil liewer meer eenvoudig bly en in my " comfort zone " bly maar wonder of die d-max nou regtig probleme gee met die common rail verandering en is ek verniet bang. Wat is die ondervinding van die manne wat albei al gery het. Sal julle opinie baie wardeer.
    Mar 2007
    Thanked: 714
    Default Re: Go Big?
    Why?
    Hi Pieterk
    As far as I know the "Go Big" model was actually a much bigger vehicle than the one it replaced, although I do not have the dimensions at hand. The 300dti engine produced 96kW and 280Nm as opposed to the 74kW and 230Nm of the 280DT it replaced.
    It received a face lift and a new line of engines in 2007 and the new D-Tec motors produced 85kW and 280NM in 250 guise and 120kW and 360Nm in 300 guise.
    Below is some photographs of an old Isuzu (similar to the 1994 model I owned) and the new one, and you can see that there is a substantial difference in size !
    The shape of the vehicle model after the 1994 model was not substantially bigger but the D Max "Go Big" (2004-2007) was 5015mm long, 1720mm wide and 1640mm high. The current model is 5218mm long, 1766mm wide and 1690mm high.
    Johan
ID:	539243   Click image for larger version.
ID:	539244   Click image for larger version.
    2011 Daihatsu Terios 4x4
  10. The Following User Says Thank You to J Snyman For This Useful Post:
    Ballito
    Thanked: 397
    Default Re: Go Big?
    Quote Originally Posted by ruger3006 View Post
    Die 3 L TD D-Max wat in rondom 2007 deur die 3 L TD D-Teq motor vervang is, was goed vir 96 kw en 280 nm. (en 500 000 km + as hy bietjie liefde gekry het). Die D-Teq motor het die krag lewerings aangeskuif na 130 kw en 380 nm. Die D-Teq 3 L TD word effektief vandag nog in beide die Isuzu D-Max bakkies en Isuzu MUX gebruik (bietjie deurmekaar tussen D-Max en D-Teq, afhangende van die jaar van vervaardiging dui "D-Max" soms n enjin reeks en soms n modelreeks aan).
    Diesel verbruik is in my persoonlike ondervinding amper identies tussen D-Max en D-Teq motors, maar sal die D-Teq dalk net n bietjie ligter wees. (en heelwat vinniger waar ookal uitkom.)
    Die huidige 3 L TD D-Teq motor is nou al meer as 10 jaar op die mark en waarskynlik die mees beproefste en betroubare turbo diesel in enige bakkie /SUV tans. (wag vir kommentaar hier������).
    Die kort en lank is - jy kan met jou oŽ toe koop.
  12. The Following User Says Thank You to jaconell For This Useful Post:
  13. #10
    Apr 2018
    Thanked: 153
    Default Re: Go Big?
    Quote Originally Posted by Redman View Post
    Go Big -
    KB5 -
    This is also the way i see it.
    2017 Isuzu KB 300 4X4 Auto (current)
    2008 Isuzu KB 300 4X4 manual (current)
    2017 Isuzu kB 250 (sold)
    2006 Isuzu KB300 (sold)
    2002 Isuzu Kb 260 petrol (sold)
  14. The Following User Says Thank You to A1ex For This Useful Post:
  15. #11
    Mar 2012
    Pierre van Ryneveld
    Thanked: 3641
    Default Re: Go Big?
  16. The Following User Says Thank You to Redman For This Useful Post:
