roof top tent hoist build bearing help.
Results 1 to 19 of 19
    Malmesbury
    Thanked: 113
    Default roof top tent hoist build bearing help.
    bought a hardshell rtt and busy disigning a pulley sistem
    i have a cable handwinch fitted to the afdak pole but need 7 small pulleys for the lifting, these pulleys will be attached to the roof supports and rtt
    i can make the pulleys and keep it as small as possible and thinking of useing 15x 35 bearings ,but my concern is the load it can handle when lifting, any engineers that help ,
    7 bearing spreaded on the load, will it handle the 100kg max . when in position it will be tied with 2 heavy duty ratchet straps .
    Colt clubcab 2.8tdi 4x4 2005
    Ford Fiesta 1.4i (SWAMBO]
    opel corsa 1.7 dti 2006
    Dec 2006
    Thanked: 90
    Default Re: roof top tent hoist build bearing help.
    I'm not an engineer, can't help with bearing load.
    I bought some sliding gate wheels ( https://www.caslad.co.za/product/gat...wheelscastors/) and use them. It works for me, also use a cable hand winch
  3. The Following User Says Thank You to Sebastiaan For This Useful Post:
    durban
    Thanked: 824
    How heavy is the tent
  5. The Following User Says Thank You to plunger For This Useful Post:
    Malmesbury
    Thanked: 113
    gate wheels ,damn ,never gave it a thought ,thanks .
    die rtt weeg 70kg ,ek het dit met die winch opgetel, van die middel van die rtt ,maar die pulley is te groot wat ek gebruiken vat spasie weg in die dak en ek wil 7 kleiner gebruik, sal more gou kyk vir die kleiner gate wiele
    ek doen draaiwerk as 'n beroep ,maar die tyd ai ..kleinte eerste .
    durban
    Thanked: 824
    Does it really need bearings if its only 70 kg.? Will follow this closely.I have a similer need but was thinking of just using delrin plastic to make the pulleys and just on shafts not bearings.
    May 2017
    Thanked: 626
    Dont you just need a Fredlin Hoist?
    DGO Fiddler
    Malmesbury
    Thanked: 113
    think a bag of cement plus half of it ,the shaft that turns in the nylon , it will be in no time a goner ,the fredlin hoist is a no no i can make things for myself ,
    Thanked: 279
    Garage door pulleys, cheapish and they last
    Neil
    durban
    Thanked: 824
    Quote Originally Posted by Alberto View Post
    Whats going to go .?The shaft or the nylon.?
    Thanked: 93
    Quote Originally Posted by EHoffmann View Post
    I agree, it's easy, all the safety and design work is done, and you're supporting a small business. I've ordered mine for next month
    Geoff Craig
    '98 Suzuki Samurai - Sami the Samurai
    '09 Toyota Fortuner 3.0 D-4D 4x4 (M)
    '10 Conqueror Comfort
  13. The Following User Says Thank You to Wave For This Useful Post:
  14. #11
    durban
    Thanked: 824
    I f you take a skiboat trailer for example .That must be 500kg easily and it lasts forever.If the tent is distributed over a couple of pulleys I would think it would reduce the weight on the individual pulleys .I just mentioned delrin cause its relatively self lubing ,cheaper than vesconite and a dream to machine as well as being unable to rust.
  15. #12
    May 2017
    Thanked: 626
    .....the fredlin hoist is a no no i can make things for myself ,
    so can I. But I pick my battles
    DGO Fiddler
  16. The Following User Says Thank You to EHoffmann For This Useful Post:
  17. #13
    Malmesbury
    Thanked: 113
    Quote Originally Posted by neoT View Post
    one of the guys in our workshop allso mentioned this ,but it will take up to much space ,the nylon will go first ,has seen this many times ,depends how much it is used ,and the wear will leave a dent in it and when you want to winch it it won't turn ,but i will agree with you turning nylon is fun made a vidio of it just fly's of the cutting tool ,nice to see.,the fredlin hoist ,it will be no lie i was drooling about it .
  18. #14
    Feb 2018
    Thanked: 698
    Quote Originally Posted by Sebastiaan View Post
    Sliding gate wheels have a recess that will pinch the rope, rather use garage door pulleys. I have done this with a 500kg handwinch, works like a charm I just have to fine tune the lifting harness.
  19. The Following User Says Thank You to River Rat For This Useful Post:
  20. #15
    Malmesbury
    Thanked: 113
    thanks for that ,if i get those wheels i will remove it and i will machine the groove out with a round tipe of tool ,problem solved.
  21. #16
    Thanked: 279
    The pulleys in my pic has done duty for almost 21years now, doors open/closed every day, there is no problem with them, other parts replaced yes but not those pulleys. How many times per month/week/day will the rtt mechanism be used? I think these pulleys will last. The size yes it might be a problem at 7cm diameter so smaller ones are in order.
    Neil
  22. The Following User Says Thank You to neoT For This Useful Post:
  23. #17
    durban
    Thanked: 824
    I made my own pulleys out of delrin plastic because nylon absorbs water and on close tolerances I was worried it might bind up on the stainless shaft I used. My pulleys I guess are only about 40mm.I wanted to use small pulleys because i had space problems.
    Its also a dream to machine plastic. My pulley system is used on a kayak of about 35kg.I just use my arms to pull it up because of the multiplication of the pulley system. Very easy. Being in Durban rust is a problem. I use 8mm nylon rope.
    Ten mm nylon rope is rated at over 1400kg. Hard to believe.This is an example of a delrin pulley.
    http://www.rileyfittings.com/pulley_...rope2inch/rm14
    Those gate wheels are unbelievably cheap.
    That friedland hoist looks interesting. Maybe I will try to make one. I like the challange of making the worm and wheel.I reckon I could make it for MORE than five times the cost of a new one.I have a very low tech solution for my canopy.
  24. #18
    Thanked: 1027
    Some thing to consider is to make the hoist/lift part be driven by a cordless drill, maybe weld a Hex bit onto the drive shaft or similar. Then you'll have effortless lifting and dropping of whatever is on the hoist, quick and easy.
  25. #19
    Malmesbury
    Thanked: 113
    done and dusted and the rtt is hanging,not even a full saterday's work and cheap as well ,38x38 x3mm tubing ,2x gatepulleys 4x turnbuckles and eye bolts ,done.
    thanks for your input ,made my mind up early this morning and went for it ,very little hickups on the build ,sorry mr fredlin ,
ID:	539099   Click image for larger version.
ID:	539100   Click image for larger version.
ID:	539101   Click image for larger version.
ID:	539102   Click image for larger version.
ID:	539103   Click image for larger version.
ID:	539104   Click image for larger version.
ID:	539105   Click image for larger version.
  26. The Following 3 Users Say Thank You to Alberto For This Useful Post:
