Suspension Fj60 brakes. Rear coil conversion
Results 1 to 20 of 24
    Dec 2016
    Ermelo
    Default Fj60 brakes. Rear coil conversion
    Hi everyone. Im not new on the forum but this is my first new thread.
    Im Charles and im buying a fj60.
    All ready found THE One. Now I'm planning some upgrades.
    Im planning on DIY all I can.
    At this point my first consern is brakes. It's got a big 8v conversion and I feel the stopping power is not equal to the going power😁
    Is there a conversion kit available to put some LC 80 or prado discs in the rear or something like that? Anny advise welcome.
    Thank you.
    Thanked: 10268
    Default Re: Fj60 brakes. Rear coil conversion
    Since your brake master cylinder is specific to rear drums, you need to replace that as well or install a brake bias valve.
    Secondly, 80%+ of all braking is on the front brakes.
    If you manage to install a set of 80 series rear disks with calipers I'd also look at an 80-series master cylinder and booster and then upgrade the front disks and calipers and pads.
    http://www.powerbrake.co.za/category_s/3718.htm
    But I'm no specialist on Toyotas. Grips and Petri know them well.
    Dec 2016
    Ermelo
    Would better quality front and rear pads and front dis make a noticeable difference?
    Would it be better to rather upgrade the front to larger discs than to convert the rear?
    Thanked: 10268
    Quote Originally Posted by 0837238277 View Post
    how old is an FJ60?
    Think about how stuffed that braking system is by now.
    Do this:
    - new disks and drums
    - new pads and shoes
    - new calipers and rear slaves
    - brake fluid flush
    - new master cylinder
    - stainless reinforced flex hoses
    You'd be surprised how it can stop if the system is new...........
  5. The Following 2 Users Say Thank You to jelo For This Useful Post:
    Dec 2016
    Ermelo
    That does seem like a good idea. Will it be enough with 33" tires?
    Dec 2016
    Ermelo
    Sorry of it seems like simple questions. Im new to the 4x4 scene. I've read a lot but dont have actual experience.
    Thanked: 10268
    depends how fast you want to drive
    There is unfortunately no way to circumvent basic physics: a 2 ton 4x4 @ 160km/h will take longer to stop than a lighter vehicle at the same speed.
    Thanked: 145
    Can the vehicle currently lock up the brakes?
    Dec 2016
    Ermelo
    My plan is simply cruising, no high-speed drag racing.
    Dec 2016
    Ermelo
    Quote Originally Posted by Wicd View Post
    I needed to step hard to get it to stop, it did not lock up. I'll take it for a test drive again in about 2 weeks then ill try to see if it will lock up. But in my experience with the amount of force I used to brake a good working system should have locked up the wheels.
    Thanked: 145
    Well, then there is room for improvement. Jelo's suggestions are good. Powerbrake discs, braided hoses etc will make a difference. Also if the vehicle is lifted you will have to adjust the load sensing valve at the back to compensate.
    Dec 2016
    Ermelo
    Is there a recommended way of adjusting that or do you go trail and error? 😁
    Dec 2016
    Ermelo
    I will be working on this car over time. What should be the first thing to check on the braking system?
  15. #14
    Thanked: 10268
    first step:
    - drain and flush the brake fluid, replace with good quality DOT4
    - check front pads and condition of calipers and disks, repair any items
    - remove rear drums, inspect shoes, inspect drum surface, inspect slave cylinders, repair any items, replace and adjust rear shoe free play
    - check condition of front and rear flex pipes
    - check for leaks
    Then take it out again. An empty FJ60 should lock up all 4 wheels. It should brake in a straight line.
    If only the rears lock: bias valve is stuck/faulty/not adjusted, or else the master cylinder is faulty
    If only the fronts lock: check and adjust bias valve until rear wheels just start to lock up under hard braking
    If you CAN'T get the brakes to lock on a hard surface, then you'll have to inspect the booster, master cylinder and again, the flex pipes.
    As I said, I'm no expert on the FJ60, but that's what I would start with on any dodgy second hand vehicle.
  16. The Following User Says Thank You to jelo For This Useful Post:
  17. #15
    Swakopmund
    Thanked: 631
    I got an 1983 FJ60.
    It very much depends on how the brakes feel. Is there a wobble? Does it pull to one side when braking?
    If it's just requires a lot of force on the brake pedal, is it maybe that 30+ years ago more brake force was required? What do you compare it to, a modern sedan?
    Check everything, brake fluid included.
    2012 FJ Cruiser
    1983 FJ60 Landcruiser
  18. #16
    Dec 2016
    Ermelo
    I got an 1983 FJ60.
    My compression is +- against the SFA hilux i had. Also with big tires. Its the closest experience i have. Is that comparable? The brakes feels to me kike something with no brake assist.
  19. #17
    Thanked: 10268
    that is a good comparison, both had solid axles and leaf springs
    your description says brake booster is not working: have you checked the manifold vacuum pipe is connected and not leaking?
  20. #18
    Dec 2016
    Ermelo
    I do not have the vehicle yet. Im paying deposit next week and should get it by November.
    For now im gathering info. Its got a ford v8 convention in so Im hoping it is something simple like a vacuum pipe.
    Im paying 45k and its got +- 200k on the clock. So i think its a bargain even if there is some work.
  21. The Following User Says Thank You to 0837238277 For This Useful Post:
  22. #19
    Thanked: 10268
    OK, let's see what happens after you get it. Doing a coil conversion isn't a trivial matter.
  23. #20
    Dec 2016
    Ermelo
    Thanks.
    After reading your reply I just realised that my title is wrong. It shoud be "rear disc conversion" 😑sorry.
