Series II Fitting Nissan 2.8 petrol to Late Series II gearbox
Results 1 to 20 of 29
    Kokstad
    Default Fitting Nissan 2.8 petrol to Late Series II gearbox
    Got a late Series II (i think), permanent 4x4, with the large rear diff. Gearbox look similar to Series 2a, but only has 2 levers.
    Need an adaptor plate for Nissan 2.8 Petrol engine. It had a RB28 in, block looks the same but bolt holes are all 5mm out.
    Who is best suited to check and partial recon Series II box in KZN ?Click image for larger version.
ID:	538676Click image for larger version.
ID:	538677Click image for larger version.
ID:	538678Click image for larger version.
    Default Re: Fitting Nissan 2.8 petrol to Late Series II gearbox
    Just drill out the bolt holes?
    Why are you removing the RD28, it's a bloody nice engine?
    Gilo Engineering makes adapters.
    Northern KZN
    Quote Originally Posted by zuluboy View Post
    Only series landy which was ever permanent 4x4, was the stage 1 V8 if memory does not fail. This is a normal series box with 4x4 engaged when you push the short lever in high range or select low range with the long lever.
    Groetnis
    Koos
    I agree with Koos. Standard series box.
    If I was doing this conversion, I'd use a Safari box and transfer case which means a standard bellhousing, standard clutch, standard flywheel, and its MUCH stronger and is also offset for RHS front and rear propshafts............
    But that's just me.
    Langs die rivier, op n berg
    Om te verander tussen rd28 enn L28 is n paar minute se werk met n boor
    I'm not sure they want to drill those holes out.
    Kokstad
    The thing is, i dont know which position is correct, because the starter can then be 5mm out on the ring gear, if i assume the bottom holes are correct.
    Kokstad
    RD 28 was stuffed,
    Starter is regte posisie.
    Brits
    Listen to Reenen...
    Nissan Patrol GRX 4.5
    Net boonste 3 gate word gerim
    Al die gate is reg, dowl is reg, net boonste 3 is uit
    Maar, n Rb25det pas presies op n Rd28 bellhousing...
    Aug 2019
    Starter mounts to the gearbox on the 2 holes that does not get drilled. just allign the bottom holes as you have the plate in the last pic and drill out the top holes. Don't go to big on the drillbit though, just enough to clear the bolts cleanly.
    Edit. I see Reenen posted the box with the markings, that is all you need to do
    Kokstad
    Thx Reenen, ek het hom
    RD 28 was stuffed,
    new ones are only R8.5k and Reenen can show you how to get awesome power out of it..........
    https://www.4x4community.co.za/forum...6-Blou-Pampoen
    That RD28 with a turbo will use much less fuel and it is BIG fun.
    Aug 2010
    Where can I get one for that price?
  19. #19
    Quote Originally Posted by Obelixs View Post
    Engines and More, Harties.
  20. #20
    Aug 2010
    Apart from the engine, what else will I need to fit this to my series 3 gearbox. (2.25 Petrol motor).
