Discovery 3 Disco 3 Post-EGR blanking cleanup recommendations
Results 1 to 13 of 13
    Cape Town, Grassy Park
    Thanked: 9
    Default Disco 3 Post-EGR blanking cleanup recommendations
    Hello
    I have done the EGR blanking and having seen the ‘cake’ build up inside the pipes, air inlets, it’s been bothering me. The fact that it’s there can not be good for the engine and it’s efficiency?
    Are there any ‘cleanup’ actions required or will the ‘cake’ layer clean itself up over time?
    Below pic with arrows showing where the major black cake layer is found, from what I could see visually without removing anything else. I should have taken pics when the Ybox was removed during EGR blanking job.
    Jul 2016
    Thanked: 458
    Default Re: Disco 3 Post-EGR blanking cleanup recommendations
    Did you not remove the EGR pipes? Did you remove the Throttle flap? Clean the MAP sensor
    Thanked: 9
    Quote Originally Posted by MikeBob View Post
    Yes, EGR is blanked and pipes are removed as you can see in the pic(sorry, this a before pic). MAP sensor cleaned and throttle valve removed.
    Perhaps I should have taken a pic of the inside to the tappet covers, I think this is what it’s called. The body where the air is sucked into as I have tried to show in the pic.
    MTUNZINI
    Thanked: 447
    Hi Schyffs , the pipes are still in place , it is not removed in your pic.
    I went the 2SO route , and my engine stays clean.
    Koos Best
    Land Rover Discovery3 TDV6 S.
  5. The Following User Says Thank You to Koos Best For This Useful Post:
    Thanked: 9
    Quote Originally Posted by Koos Best View Post
    Oops, this is the before removal pic, sorry.
    Disco 3 2.7 Tdv6 fault codes EGR
    https://r.tapatalk.com/shareLink?sha...9&share_type=t
    Here is the link to the actual removal thread.
    Thanked: 9
    Apologies, the pic was the before shot. All those recommendations have been done.
    Thanked: 9
    Did you do any additional cleaning of the EGR and the intakes etc, besides the Ybox and intercooler pipe box to remove the black cake layers?
    Oct 2015
    Thanked: 32
    Must you clean the build before using 2SO?
    Discovery Landrover 3 tdv6 2008
    Volvo S40 T5 2006
    Thanked: 9
    Quote Originally Posted by Shade View Post
    What do you mean by the 'build'?
    Oct 2015
    Thanked: 32
    Build up of muck
    Volvo S40 T5 2006
    Thanked: 9
    Build up of muck
    I’m not the expert, so was asking the basic question myself.
    From what I found when doing the EGR blanking, the only place that I could clean was the Ybox and the MAP sensor that is fitted in the same box.
    All the posts I read about this topic of 2SO, not much is mentioned about doing any excessive carbon cleaning. But I suppose doing as much cleaning where you can get into without dismantling the engine is about all that can be done.
    Oct 2015
    Thanked: 32
    Thanks that is the clarity I required....not dismantling the entire engine which as I understood it, its not required.
    Volvo S40 T5 2006
    Thanked: 9
    The reason for my original post and question is because I have come across websites of specialists that do engine carbon cleaning. They all have different methods but the end result is the same.
    So, is it recommended to do a carbon clean up on the TDV6 since it was exposed to EGR gasses? Has anyone done this on their TDV6?
