Jimny alternator recondition - Western Cape
Results 1 to 4 of 4
    May 2008
    Edgemead
    Thanked: 16
    Default Jimny alternator recondition - Western Cape
    Hi everyone
    I suspect my alternator needs a recon. I have a terrible fan belt noise (in the morning especially) when I switch the lights, fan or aircon on. I have already replaced the belt and retentioned it , but the problem returns after a while. I have had the tensioner pulley checked and it seems fine. The noise goes away if I switch to Dimm lights or switch the lights off.
    My next step is to have the alternator reconditioned/serviced. Can any one recommend a good auto electrician in Cape Town that has worked on Jimny's.
    Marius
    Marius Reitz
    Suzuki Jimny (Puddle Jumper)
    Old Man Emu kit, branch, free flow exhaust...
    Astronomy and Telescopes
    Dark Sky Director for ASSA - Cape Center
    • 13.1 inch custom built truss telescope on a dobsonian mount
    • 8 inch Skywatcher reflector on a Celestron CGEM mount
    • 6 inch Orion reflector on a EQ5 mount
    • 6 inch Konus Maksutov Cassegrain on a EQ3 mount
    • 15x70 Celestron Skymaster binoculars on a parallelogram mount
    Brackenfell
    Thanked: 227
    Default Re: Jimny alternator recondition - Western Cape
    Quote Originally Posted by 4WD View Post
    Hi everyone
    Marius
    You could contact Mario (Marshall Services), he is in Edgemead as well. Wemmerspan Rd IIRC. 082 nine28 32one0
    Thanked: 129
    The Jimny has two belts: One that drives the power steering and aircon. The tensioner is for that belt. A screeching fanbelt is usually the second belt that drives the waterpump and alternator, and to tension that belt, you'd need to adjust the tension on the alternator.
    I had the alternator on my Jimny recon'd at a local auto electrician in Strand.
    Thys de Wet
    Jimny 2009
    Ek het nou klaar gewerk, maar ek weet nie of die bank daarvan gaan hou nie...
    May 2008
    Edgemead
    Thanked: 16
    Thank you. I contacted him, but he does not do auto electrical work.
    Marius Reitz
