TD5 Engine Vibration at 2250 rpm: Anyone found the cure yet?
Results 1 to 20 of 26
    Thanked: 1289
    Default TD5 Engine Vibration at 2250 rpm: Anyone found the cure yet?
    My Disco 2 TD5 has what I can describe as a "drone" noise which occurs in a narrow band between about 2000 and 2250rpm.
    Above and below that, it is smooth, but it happens in all the gears and while revving freely.
    Googling the problem, is it clear that this is a common problem experienced by many (if not eventually almost all) owners and yet there is not a single reference to where a solutions was found.
    It also seems that there is no evident ill-effects that propagates beyond this vibration and that the irritation of it is the biggest problem.
    To get around it, is as easy as simply driving over or under it, but it is irritating if the speed you are forced to cruise at happens to be in that range.
    I cannot yet figure out if the problem is more noticeable in the Auto than the manual, but it seems to happen in both, and regardless of ancillaries like ACE bolted tot he motor.
    Further more, it seems that here and there engines other than the TD5 has the same problem and that it gets to the point that "this is how they are".
    From my quick assessment then, it can only be on the engine side and since it was on most of them not there since new and only later in life, sure are hell there must be something that cause it that can be repaired.
    Some people reckons it being a 5-cylinder has something to do with it. Perhaps it could be, but on the other hand 5-cylinders have been running for decades in many applications and this is not a default 5-cylinder engine-type problem.
    Does anyone know if a cure has been found yet?
    My idea for now it to at least connect a knock sensor on various parts of the motor and at least put in on an oscilloscope so that one can determine if it happens in cycles at the same RPM, or half RPM or whatever.
    1999 Discovery 1, 300 Tdi - "Tink Tanky"
    2004 Discovery 2 Td5 - "Blink Tanky"
    "Logic is a systematic method of coming to the wrong conclusion with confidence."
    "A technician will let a system degenerate to the level of his understanding and maintain it there."
    "...it is abundantly clear that you are an arrogant C-nut." - Estee. (I was overwhelmed. It was the nicest thing someone has said to me in a week!)
    Thanked: 10058
    Default Re: TD5 Engine Vibration at 2250 rpm: Anyone found the cure yet?
    Harmonics are a sod.
  3. The Following 2 Users Say Thank You to jelo For This Useful Post:
    B-gowrie Randburg
    Thanked: 194
    The turbo typically comes in between 1800 and 2200 revs but its a welcome upstaging ‘event’ and not
    something Ive in anyway thought to be problematic ... no conspicuous or discrete sound or vibration pick-up just feel more capability coming from the motor.
    Possibility that the turbo coming in on your motor/s emphasises/highlights some other problem/s ?
    Land Rover Owners dont idle long ...
    2002 130 DC HCPU //81 R-Rvr Classic 2-Dr 3.5L V8.
    75 Series3 88 PUP.//17 Metalian Mini (Home from Home)
    Thanked: 1289
    Quote Originally Posted by BushNomad View Post
    No.
    Oct 2015
    Thanked: 69
    Hi Biltong
    Yes the Td5 vibrations. A bugger to diagnose. If you say it happens when you rev it freely you can narrow it down to the engine other than when the vehicle is moving because that brings all sorts of moving parts into the mix.
    I also have a vibration and got it narrowed down to the engine mounts or the harmonic pulley.
    Mine not so continous but noticable.
    ONE LIFE!
  7. The Following User Says Thank You to Wildkyker For This Useful Post:
    Thanked: 1289
    Hi Biltong
    Engine mounts are brand new on mine. Thew other were really buggered. Off course that alone made one helluva difference. But it aint good enough.
    Have not checked the pulley yet, but that is definitely on the list.
    Feb 2012
    Thanked: 58
    Would be interesting to find out what it is. Have the same on mine, but I suspect it could be engine mountings, as she has 300K kms already.
    Another irritating drone noise I have is around 1500 RPM, which sounds as if it is from the exhaust system. Here I suspect the expansion thingy on the exhaust just below the turbo could be the culprit as it is just a noise and not a vibration.
    Gary W
    Thanked: 1289
    They do say the flexplate also develops cracks around the bolts.
    The reality is that it may not be one part, but a combination of parts that goes which cause it.
    So it may be the pulley AND the flex plate.
    Thanked: 1289
    I decided to replace that pulley in any case.
    It can result in a fairly catastrophic failure due to age, and I certainly would not want that to happen in the middle of nowhere.
    Thanked: 559
    Biltong, you're busy overloading my "subscribed" threads...
    ENJOY!!!
    Ettienne
    1980 Range Rover
    2002 Defender Td5 D/C
    2004 Disco Td5
  13. #11
    Thanked: 10058
    Harmonic balancer is my first guess. If it is manual, then the dual mass flywheel is the second suspect.
  14. The Following 2 Users Say Thank You to jelo For This Useful Post:
  15. #12
    Thanked: 1289
    That would be my guess as well.
    Anything that has to dampen vibration, has to go first. No point in any evaluation before that.
  16. #13
    Thanked: 1289
    Jong, jy sal versigting moet wees.
    My hartjie is pikswart en ek vertroetel hom om so te bly.
  17. The Following User Says Thank You to biltong For This Useful Post:
  18. #14
    Feb 2012
    Chintsa East
    Thanked: 408
    Flywheel.
    2013 Disco 4 XS Lifted
  19. #15
    Thanked: 1289
    Quote Originally Posted by pwgg View Post
    Flywheel.
    Auto...
  20. #16
    Robertson/ Larissa, Greece
    Thanked: 2551
    It may be totally unrelated, but I have picked on some engines where the intake system causes a drone at certain revs. Maybe disconnect at the intake manifold and take it for a run. Just an idea.
  21. #17
    Thanked: 1289
    Francois,
    For the moment, I doubt it is that. The drone is not only sound, it gets transmitted along the exhaust system as well and with the middle box on my one that was an abortive installation, I initially though it was that.
    I had that rectified yesterday, and there is a good improvement, but only because the new system are now equally suspended on the brackets where as the previous one was straining against them.
    It seems that the general way things are going is that at it was not there when new, and sort of develops within a short period of time somewhere in future.
    I am inclined to think that the crank pulley - or as Land Rover calls it - the harmonic balancer is the most likely culprit and a good candidate to replace not only for possibly solving this problem, but because it can fail catastrophically.
    For now, I am going to make that my first point of call.
    Koos
  22. #18
    Thanked: 710
    If you're going to change the flex plate get this one, more expensive but will last longer.
    https://www.ashcroft-transmissions.c...c-4713-hd.html
  23. #19
    Thanked: 2551
    I would imagine that on a 5 cylinder diesel a harmonic balancer will get a bit of a workout, so not a bad idea to replace irrespective.
  24. The Following User Says Thank You to Francois Theron For This Useful Post:
  25. #20
    Richards Bay
    Thanked: 11
    Mine did this, TD5 D90, not even Land Rover Empangeni could tell me what it was, I took a chance on the flywheel.
    Turned out I was 100% on the money, replaced it and all was fine.
  26. The Following User Says Thank You to Jacoviss For This Useful Post:
