Disco 3 break light not working
Results 1 to 7 of 7
    Oct 2015
    Default Disco 3 break light not working
    Hi, I have a 2005 Disco 3 v8 SE. the right hand break light has stopped working. The tail light part of the bulb works fine. I have replaced the bulb, checked the contacts and the wiring that I can see and all looks fine. The left hand break light works fine. Any suggestions as to where to look next or what the cause could be?
    Ross Haydock
    2005 Land Rover Discovery D3 V8 SE
    2005 Land Rover Defender Td5
    Quote Originally Posted by Ross_H View Post
    If you used a cheap globe itís possible that the quality isnít as good as youíd think and the globe is a dud. For some or other reasons OEM bulbs are if a better quality.
    May 2013
    Thanked: 22
    Default Re: Disco 3 break light not working
    Hi, only the original from LR works sadly. Replaced a few myself.
    2007 Discovery 3 V8 SE
    2015 Hyundai IX 35 Limited Edition
    Mar 2018
    Goba
    Thanked: 139
    There is a few fuses in the left rear compartment (Standing at the back looking to the front)
    Where your Jack is stored.
    It also hold the fuses for the door solenoids.
    Yes, and only real L/R bulbs works
    You can even get a system fault with wrong bulbs
    1997 Discovery 1 300 TD i ...Old Faithful
    2006 Discovery 3 2.7 TDV 6...not sure yet ?
    Oct 2015
    Thanks everyone for the suggestions. I have replaced the bulb with one from Landrover but still not working. Will check the fuse this morning. Hopefully thatís all it is.
    Thank again
    Ross Haydock
    Oct 2015
    Ok, so the fuses are all fine. So just purchased a box of bulbs from Landrover and went bulb dy bulb and can you believe it, 5 bulbs later it is now working? Go figure. Anyway, itís working for now.
    Ross Haydock
  7. The Following 2 Users Say Thank You to Ross_H For This Useful Post:
    Feb 2012
    Brackenfell
    Thanked: 44
    From your local parts shop, Osram and OR Phillips branded 12v globes are just as good, if not the same as your LR parts bin.
    2009 Range Rover Sport 4.4 V8 HSE (his)
    Izmir Blue
    2012 Audi S3 (hers)
    Brilliant Red
