So much Dust in my RSI Canopy :( - Page 2
Page 2 of 2 FirstFirst 1 2
Results 21 to 28 of 28
  1. #21
    Swakopmund
    Thanked: 631
    Default Re: So much Dust in my RSI Canopy :(
    I used to have an Isuzu KB200, a Ford Ranger and an Amarok. All with normal fiberglass canopies, e.g. Beekman. All I had to do was leave the canopy side windows open a bit / prevent them from closing. Very little dust in the load bay, at any speed. I never bothered with dust kits and stuff. Seeing that you don't have sliding windows on your canopy, a decent vent flap should do the job. Maybe fit a 2nd one on the other side.
    2012 FJ Cruiser
    1983 FJ60 Landcruiser
  2. #22
    Sep 2018
    Thanked: 90
    Quote Originally Posted by The_Pantoffel View Post
    HI All
    I've got the RSI Canopy for my Bakkie, and the extra sealing between the bakkie-flap to close that little bit off when opening.
    However, when doing dirt, which I do a lot of, everything is full of dust...
    Are there are other things one can do do minimise the dust?
    CHeers
    Pantoffel
    Lots of useful info here: https://www.4x4community.co.za/forum...itive-pressure
  3. The Following User Says Thank You to Lxv For This Useful Post:
  4. #23
    Otjiwarongo
    When my roof rack is fitted for a trip, all airflow into my canopy is affected even with an air flap installed on top of the canopy. At low speed no positive pressure can build-up in the canopy.
    I purchased a universal electrical radiator fan (R500-00) and installed it in the canopy underneath the air vent. When the fan is switched on, there are no dust entering the canopy irrespective of the speed I travel. No tailgate dust kit or any sealing done.
  5. The Following 3 Users Say Thank You to Garmin68 For This Useful Post:
  6. #24
    Mar 2007
    Thanked: 713
    Can you perhaps indicate from where on hat door the dust falls into the bin?
    Please give us feedback - we are all learning
    I took this photo in the Khowareb Schlucht today ! (Phone seems to load in upside down ....)
    Johan 😎
    2011 Daihatsu Terios 4x4
  7. The Following User Says Thank You to J Snyman For This Useful Post:
  8. #25
    Thanked: 86
    Quote Originally Posted by J Snyman View Post
    Johan 😎
    Johan that would be sorted by one of those Valiant style aerofoils so popular in the 60ís and 70ís - like one central above the tailgate and 2 on the sides. Been searching the Net for those but canít find it anymore. Sure it would sell well if someone here could start manufacturing it again.
  9. The Following User Says Thank You to Sadi For This Useful Post:
  10. #26
    Melkbosstrand
    Thanked: 160
    Johan 😎
    I haven't had that issue, but then, I have a roof rack fitted... must create enough turbulence to stop the buildup
    2015 VW Amarok 4motion Auto
    2011 Conqueror Companion
  11. The Following User Says Thank You to BobMabena For This Useful Post:
  12. #27
    Jan 2018
    Pietermaritzburg
    Comments regarding the load bin are spot on . Also check that the dome vent usually fitted to the roof of the canopy has the largest hole facing the front
  13. #28
    Mar 2007
    Thanked: 713
    You are not going to get airflow via aerofoils or roofracks when doing low speeds in conditions like these ....
    Johan
