Zambia power points
Results 1 to 10 of 10
    Apr 2012
    Jhb
    Thanked: 97
    Default Zambia power points
    can anyone advise the type of power points in lodges and camps in Zambia?
    Will a normal South African round three point plug fit?
    Ruimsig
    Thanked: 10390
    Default Re: Zambia power points
    Quote Originally Posted by RonS View Post
    Some lodges have both next to each other, some dont. You need the square 3 prong adapter for just in case.
    Estee = S T = Sean Towlson
    Hummer H3 V8
    W.A.P Objectivist
  3. The Following User Says Thank You to Estee For This Useful Post:
    livingstone
    Thanked: 163
    Its a difficult one, a few years ago the Zambian government banned the sale of any appliances with the round pin plug. 3 pin square is actually more common; however some places only have round pin, some have square pin and some have both.
    Bring adaptors for both.
  5. The Following User Says Thank You to tripodontour For This Useful Post:
    Jan 2017
    Thanked: 237
    A lot of places have the UK plugs tjey are in the majority.
    Nov 2006
    Thanked: 216
    Quote Originally Posted by Fishing1 View Post
    Jip, just get a UK adaptor and you should be fine!
    Bostoe
  8. The Following User Says Thank You to bostoe For This Useful Post:
  9. #6
    Apr 2012
    Jhb
    Thanked: 97
    Thanks everyone, I will take a round and square three pin.
    Maybe the three pin square was inherited from the UK?
  10. The Following User Says Thank You to RonS For This Useful Post:
  11. #7
    Jul 2013
    Brentwood Park
    Thanked: 420
    I just spent a month there and I never once saw a plug like ours. You should definitely take an adaptor.
  12. The Following User Says Thank You to Chopped For This Useful Post:
  13. #8
    Ruimsig
    Thanked: 10390
    Yip, their entire system is similar (except for plugs) as ours and also inherited from the British.
    Hummer H3 V8
    W.A.P Objectivist
  14. #9
    Florida
    Thanked: 644
    I assume all your plugs (and multi plugs) are the round ones, some 3 pins and some 2 pins. Then all you need is an adapter to take them to the square plugs. Plug in your multi plug (which has both 2 and pin round holes) and and use as you do here.
  15. #10
    Apr 2012
    Jhb
    Thanked: 97
    Thanks, will get an adapter.
    Useful info as it won't be easy to get an adapter once on the road!
